Side Marker Lights
Old 04-30-2008 | 05:57 AM
amacgenius's Avatar
amacgenius
Default Side Marker Lights
That's the part I want to replace, I've got a set of clear ones that I've been itching to put on my Neon, any help anybody?
Old 04-30-2008 | 11:23 AM
inthewerks's Avatar
inthewerks
Default RE: Side Marker Lights
never done mine before but there should be a couple of screws holding your amber ones to the bumper. if you stick your hand up there, see if you can get a screwdriver in there. you might need to remove the air intake baffle box thing that attatches there. then its just a simple swap. remove wire harness and bulb from amber side marker, install clear side marker, install harness and bulb to new side marker. and your done. real simple.
Old 04-30-2008 | 12:39 PM
mat663's Avatar
mat663
ORIGINAL: amacgenius
Hi, where did you get your clear ones from? The only place i can find them is on eBay for about $20...is there anywhere else i can get it for a little lower? or is that the lowest it can get?
Old 04-30-2008 | 02:12 PM
Baddog44's Avatar
Baddog44
removing those is simple. Just go underneath the bumper and see where the maker is at. You will then see a pin holding the marker in place (you may need a flashlight to see it) pull that pin out then you can remove the marker. Disconnect the connector (which has the bulb) from the marker and put in the new one. Then do it the same way for the other side.
Old 04-30-2008 | 02:21 PM
Adionik's Avatar
Adionik
If you can't change your sidemarkers blind folded then you seriously shouldn't be allowed near a Neon. It's the easiest thing to swap out next to the spoiler
Old 04-30-2008 | 02:38 PM
contagious19's Avatar
contagious19
ORIGINAL: Adionik
yea, i just stick my hand in there and pull the pin off. i dont even remove a bolt
Old 04-30-2008 | 08:06 PM
LowSlowNeon's Avatar
LowSlowNeon
It is only held on by a metal clip. Granted one of them was a bit of a pain to remove, but still not that hard.
Old 04-30-2008 | 10:29 PM
amacgenius's Avatar
amacgenius
I got mine on eBay.
Old 05-01-2008 | 09:36 PM
inthewerks's Avatar
inthewerks
sorry guys. i thought they were held on by screws or something. like i said i never did the swap yet. i guess the mod is a piece of cake.
Old 05-02-2008 | 10:11 AM
blocks885's Avatar
blocks885
while you're in there, purchase some clear bulbs that shine amber... or buy a clear led that shines amber. i chose the led that shines amber, looks a LOT better!
Quick Reply: Side Marker Lights
