I'm going turbo. I want to hit 12-15 lbs of boost, I know that complete bottom end will be needed. What cam should I use for a daily driver with that much boost? I was thinking the 12 from Crane whould be good enough. Should I get the head overhauled? It's going on a 2002 SXT mtx.
I would go with the #14, if you are gonna go with the higher boost. Other than surfacing the head and a new gasket, nothing is needed for the head however any head work you do is only gonna help, if done right
