New Guy Trying to fix Mother In Laws Neon.
Old Jul 12, 2008 | 02:55 PM
  #21
jmcd's Avatar
jmcd
Default RE: New Guy Trying to fix Mother In Laws Neon.
Well it's not the map sensor . I started it up and sounded good for a second jumped in hit reverse and barely wanted to move !!!!!!!!! Now I don't know if I should try wires or what??? And,, yes ... X2,000 your guys are awesome and thank you very much for all your help. I am going to go chech the grounds again and look for shorts. For the Map I didn't have to reset anything did I ?? Or is it just replace then start-n go..
Old Jul 12, 2008 | 03:05 PM
  #22
bone33's Avatar
bone33
firing order is marked on the coil pack. see my painting
Old Jul 12, 2008 | 03:10 PM
  #23
jmcd's Avatar
jmcd
What is Number 1 Closest to pulleys or flywheel
Old Jul 12, 2008 | 03:14 PM
  #24
bone33's Avatar
bone33
check out my paint skillz!!!!
  #25
jmcd's Avatar
jmcd
MIne From the front of the block just go 1234 from what the coil pack is indicating.
Old Jul 12, 2008 | 03:18 PM
  #26
jmcd's Avatar
jmcd
Yep thats how mine look ! Farg !!! I think i'll go grab some wires if it is just the wires I am going to kick myself!!!!!!!!!!!!
Old Jul 12, 2008 | 03:21 PM
  #27
bone33's Avatar
bone33
now all you gotta do is fix your mother in law and you will be all set.
Old Jul 12, 2008 | 03:45 PM
  #28
jmcd's Avatar
jmcd
Nope not the wires,, Man this thing is killing me !! So i have the tps and some oil sensors left or the coil pack?
Old Jul 12, 2008 | 03:47 PM
  #29
jmcd's Avatar
jmcd
Should I try the crankshft sensor next?? Also do I have to reset anything for the computer to read the new sensor or is that automatic?
Old Jul 12, 2008 | 04:12 PM
  #30
Izero's Avatar
Izero
reset it just to be sure... and to see if the codes go away...... the crankshaft sensor should be replaced by a professional... just my opinion... i dont like to mess with OEM sensors unless its something simple like a MAP, TPS, O2 or something along those lines.... so yea... ummm leave the crank sensor off to the last thing that you do... that will be the last resort...
