What the heck is that?
Old Jul 27, 2008 | 10:05 PM
ricerchik02's Avatar
ricerchik02
Default What the heck is that?
Every time I take a hard left or when I have two or more people in my back seat, my right rear wheel makes a lound clunking noise. Any idea what this is?
Old Jul 27, 2008 | 10:15 PM
srtgtr34's Avatar
srtgtr34
Default RE: What the heck is that?
These are the first three things that came to mymind, Loose wheel, a broken strut or you need new bushing's because one or more has let go.
Old Jul 27, 2008 | 10:17 PM
ricerchik02
Well I know for sure the wheel is not loose. That was the first thing I checked.
Old Jul 27, 2008 | 10:22 PM
srtgtr34's Avatar
srtgtr34
Tommorrow you should try to get under the car to investigate, either way check the bushings.
Old Jul 27, 2008 | 10:26 PM
ricerchik02
Sounds fun not really lol. I've never checked bushings before. What do I look for?
Old Jul 27, 2008 | 10:54 PM
srtgtr34's Avatar
srtgtr34
I would check these 8 spots:, don't worry about the numbers.
Old Jul 27, 2008 | 11:51 PM
Exubus's Avatar
Exubus
Good info. Also check the spring where it seats at the top of the fender well, around the strut mount... there is a rubber gasket up there that the spring seats itself in. Under heavy load/cornering, the spring can make a popping sound as it rides in and out of the rubber. Happened to me.
Old Jul 27, 2008 | 11:59 PM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
Iowa what hasnt happened to you? LOL. Like they said it sounds like a strut. How is the ride when you hit a bump? Does your back end bounce around? Does your back end sag when you have people in the back?
Old Jul 28, 2008 | 12:10 AM
Exubus's Avatar
Exubus
No no, I didnt have a prob with the strut, only the spring and the rubber piece that it rests in. And I would hope that her rear end sags a bit when she has junk in her trunk, unless she has REALLY stiff springs in it lol.
Old Jul 28, 2008 | 12:24 AM
KARR's Avatar
KARR
I mean if it sags alot. Just push down on the back end if it goes down easily you have a problem with the strut.
