Coolant Flush Help
Old Aug 25, 2008 | 03:59 AM
Izero's Avatar
Izero
got it at my local auto parts store.... do a search for the thread i think ricer chick started... or search for my post about a coolant flush and you'll get more info no worries!
Old Aug 25, 2008 | 04:16 AM
Exubus's Avatar
Exubus
Bump, boom:
https://dodgeforum.com/forum/showthr...hlight=coolant
FYI I ended up doing this a month or so ago, went with the Prestone. Yes, it is green. No, it is not like the old green stuff. Yes, it is more than safe for the aluminum in our cars and has the anti-corrosion mix already in it. I blended a 70/30 mixture myself, for maximum operating range.
Old Aug 25, 2008 | 05:16 AM
N30N's Avatar
N30N
???^^^ what???
djmagic's Avatar
djmagic
ok so should i use the valvolind zerex or the prestone 50/50?
Old Aug 25, 2008 | 05:19 AM
N30N's Avatar
N30N
http://www.valvoline.com/pages/produ...asp?product=10
same here...im doing this thur or wed so i need to know by then...
like where can we get this stuff ricer chick used and i know where to get prestone
Old Aug 25, 2008 | 08:05 AM
Exubus's Avatar
Exubus
Good link N30N.
Bottom line, if you do a proper system flush the way you should (I drained mine, then filled it with pure water, ran the engine, then drained again, then filled it with pure water + flush solution, then ran it, then drained again, then filled again with just water, ran it, then drained again... then FINALLY filled it with new coolant to somewhere between a 65/35 or 70/30 mix, and I used zero tap water, which is important) then you will be fine.
This coolant debate has been going on all over the internet. Bottom line, unless you do something really obnoxious, there are a lot of different possible types of coolant you could use. Not all, but a lot. The only horror stories I have ever heard are from people who seriously neglect their car, or have no business being under the hood in the first place. Doing your research is a great idea, but there is no one single "magic" brand that must be used in our cars.
Bottom line, do a proper flush, use a newer technology coolant (not one that's been sitting in your garage for the last 20 years) and do not mix different brands of coolants, and you will be fine.
Originally Posted by N30N
???^^^ what???
What? lol
Old Aug 25, 2008 | 03:51 PM
djmagic's Avatar
djmagic
so pure water with flushing solution, hose water and then i should be fine with the regular prestone 50/50 iowa. Also iowa when you mean pure water like the water you use for aquariums. Like reverse osmosis such as the water you can get from the machines in walmart
Old Aug 25, 2008 | 04:05 PM
Exubus's Avatar
Exubus
Ha, no... I meant when you are doing the flush, "pure" water meant "plain" water, or water with nothing added to it, no coolant, etc etc. In other words, 100% garden hose is okay for the flush.
However when you fill up with new coolant, make sure you use clean, distilled/de-ionized water only, and NOT garden hose or anything else.
Old Aug 25, 2008 | 04:56 PM
djmagic's Avatar
djmagic
ok iowa. Alright then i'm just going to do the premixed prestone probally.
Old Aug 25, 2008 | 07:39 PM
Izero's Avatar
Izero
yea... and did you let the car run up to operating temp or did you just turn it on run it for a few min. and then drain it...? anyways wouldn't that leave some water in the block...? i thought you wanted to let it all settle in the over flow and radiator, which gives you the most efficient drain... then you just rinse out the radiator... and drain the remaining stuff left over after u flush it.... damnit people just go buy a freakin' Haynes repair manual, it tells you each and EVERY step on how to flush the coolant... and the premix stuff is a god send! :-D
