What battery do you guys recommend?
Old 11-25-2008, 11:15 PM
mjs182004's Avatar
mjs182004
mjs182004 is offline
Originally Posted by pasgaines
i bought mine it had a anti corosion thing hooked up it looked like stock but maybe someone before me put it on, and my headlights are starting dim if i turn my stereo up, so i am thinking i have to get a new battery soon also.they didn't start this till about 2 months ago.
sounds like you might also want to think about getting a capacitor too. only if you have subs in the trunk that take a lot of power.
Old 11-26-2008, 08:57 AM
AnthemBassMan's Avatar
AnthemBassMan
AnthemBassMan is offline
-I just bought a new one from NAPA for my '05 SXT. Just the stock replacement one. Cost me $54.88 including tax.
L8R,
Matt
Old 11-26-2008, 09:50 AM
technical18's Avatar
technical18
technical18 is offline
Optima Yellow Top FTW!
Old 11-26-2008, 01:54 PM
underground6t9's Avatar
underground6t9
underground6t9 is offline
I run the optima yellow top on my ride. Its been the best battery I have had. I highly recomend it.
Old 11-26-2008, 02:31 PM
ewetho's Avatar
ewetho
ewetho is offline
Conventional batteries are made by one of 3 companies in this country. Brands do not matter much. Most of Wally is Johnson Controls I think so same as Mopar, Motorcraft, Interstate, Die Hard, Duralast etc....
The Optima (and others like it) are very good batteries but expensive.
Old 12-24-2008, 10:12 PM
mcfisher1980's Avatar
mcfisher1980
mcfisher1980 is offline
Optmia yellow top FTW
Old 12-24-2008, 10:32 PM
mcfisher1980
go with an optmia yellow top if you can afford it. part number d35. perfect fit. i have one in my 04 neon sxt. the bad thing is you wont be able to use the battery heat protector bag thing that goes over the stock battery. which you really dont need anyways
Old 12-26-2008, 02:34 AM
mat663's Avatar
mat663
mat663 is offline
i might need one soon too because every few weeks, my terminals would build corrosion on it and i gotta clean it. The corrosion sometimes prevents my car from starting because they block electricity flow to the starter.
Quick Reply: What battery do you guys recommend?
