srt-4 brakes and timing belt
Old Feb 9, 2009 | 11:32 AM
Dorin_82's Avatar
Dorin_82
Smile srt-4 brakes and timing belt UPDATE
just got the rear set-up to swap it in instead of my rear drums. i'm looking for some stainless steel brake lines also. i'm wondering if the front lines are the same on the srt and my se, so i can order the whole srt lines set.
also, for the timing belt tensioner, can i swap a 03-05 mechanical on my 01 hydraulic, is it a bolt on?
Old Feb 10, 2009 | 01:10 AM
Dorin_82's Avatar
Dorin_82
bump^^^. anybody?????
Old Feb 10, 2009 | 10:45 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
i think the lines are different in the front of an srt and an se... i am not 100% yet i have not found a set up to swap everything over to srt brakes so i dont know forsure... where did u get ur rear disk setup from?
Old Feb 10, 2009 | 12:40 PM
NeonOn19s's Avatar
NeonOn19s
you should be able to use the SRT kit on your SE. there shouldn't be any difference really.
Old Feb 10, 2009 | 01:24 PM
tooslow's Avatar
tooslow
yes you just have too cut the plastic so it sits flush with the block or just buy the covers for a 03+ from your dodge dealer it is under $50.
Old Feb 10, 2009 | 10:11 PM
contagious19's Avatar
contagious19
i dnt think u can swap the tensioners
Old Feb 10, 2009 | 10:56 PM
mcfisher1980's Avatar
mcfisher1980
you cant. i asked about that when i got my timing belt changed and was told that it wouldnt work
Old Feb 10, 2009 | 11:09 PM
Dorin_82's Avatar
Dorin_82
who did u ask? dealer mechanics are not gonna tell u if it can be done or not. i know the blocks are the same, don't know if there are threads for the bolts to hold it.
DT, i got it on e-bay, there's a guy that always has them. i paid 220. didin't got them yet, hope by the end of the week. heard on 2.gn some people had some problems w this guy/seller. i'll se what i get and keep u posted.
anyways, i'd still like some answers for my questions if anybody knows for sure^^^^^^
Old Feb 10, 2009 | 11:20 PM
mcfisher1980
i used to work for dodge. i still keep in touch with a few of the techs and the service manager. so while i was up there getting my w/p and timing belt changed thats when i asked. yes both tensioners look the same, but they opperate and are mounted differently.
Old Feb 11, 2009 | 09:23 AM
Dorin_82's Avatar
Dorin_82
i know they are mounted differently. but the blocks are the same. that means the location for the mechanical tensioner is there. just wondering if there are threads in the block for it. cause if there are, there's no reason not to work.
