oil sending unit
Old Mar 3, 2009 | 05:24 PM
srt4rez's Avatar
srt4rez
Default oil sending unit
Does anybody know where to run the oil unit for a mechanical oil line? I removed the oil sending unit...is that the only place to hook it up from? 2004 SXT Dodge Neon 2.0L
Old Mar 3, 2009 | 05:31 PM
srt4rez's Avatar
srt4rez
Default Sway bar
All srt4s use 22mm and mostly all standard neons use the 20mm sway bars,right? Correct me if I'm wrong. I'm talking stock. So the rubber bushings will either come in 20mm or 22mm....right? Always something new to learn.
Old Mar 4, 2009 | 02:09 AM
neonftw87's Avatar
neonftw87
i would say best way to get an answer to this would be from a dodge dealer, or you could also check the SRT4 forums too, theres a few swappers in there that would probably know about it... sorry im not much help here man... gl tho
Old Mar 6, 2009 | 10:30 AM
blueproracer's Avatar
blueproracer
you can "T" it in there. my turbo oil feed and oil press send unit feed like that. or you can check around your oil filter. if it is already equipped with a sandwich plate, you can go there. any napa will have a T . just take you oil sensor and oil guage fittings in to match up threads. it will be a brass plumbing fitting.
Old Mar 6, 2009 | 01:56 PM
darthroush's Avatar
darthroush
Section Moderator
I was going to say to "T" it as well. On the 2.4's, there is a spot you can actually feed a line to and not have to "T" it, IIRC.
Old Mar 19, 2009 | 01:06 AM
neonftw87's Avatar
neonftw87
i was thinkin about the swap, but i figured it would be way too much hassle.... as a matter of fact guys, if you ever wanna do a SRT4 swap, theres a company online you can google, that pays for your hotel stay and all it takes only a weekend and they do a full swap for you for like 5000 bucks.. or more depending on addons you want to add.
Old Mar 19, 2009 | 09:45 AM
OhNo2.0's Avatar
OhNo2.0
ibbunchofbumsreadytostealcars
Old Mar 24, 2009 | 12:06 AM
neonftw87's Avatar
neonftw87
lol nah they let you moniter the progress, i see what your saying tho... but then again, what would they want with a bunch of 2.0 neons lol its a legit site, lemme find the URL and ill post it
