2000 Dodge Neon Firing Problems
Old Mar 27, 2009 | 12:54 PM
duval103's Avatar
duval103
Default 2000 Dodge Neon Firing Problems
Everything is working fine. The only problem is that its not firing. I have new spark plugs, a programmed ECU, new fuel and new fuel pump. For some reason its not getting the signal to fire. Does anyone know how to fix this problem?
Old Mar 27, 2009 | 03:47 PM
darthroush's Avatar
darthroush
Section Moderator
How's the coil pack?
Old Mar 27, 2009 | 06:20 PM
Freerider's Avatar
Freerider
If it's cranking fine, and just not sparking, the problem lies in your coil pack, spark plugs, or wires.
It could very well be an issue with your coil pack. I am with Roush
Old Mar 28, 2009 | 01:55 AM
darthroush's Avatar
darthroush
Section Moderator
BTW, what plugs did you put in and what gap? What wires are you running? Still leaning towards the coil pack, but certain things could make it worse I suppose.
Old Mar 28, 2009 | 10:47 AM
duval103's Avatar
duval103
Its a little awkward. When I came home last night my dad had the car running. He said it short curcuits when ever the camshaft is wired. When he disconnects it he is able to start the car fine. So now that i know its a short curcuit somewhere I wonder what could fix the problem. A stronger battery?
Old Mar 28, 2009 | 05:20 PM
darthroush's Avatar
darthroush
Section Moderator
If something is shorting, I wouldn't want to try and pump more energy into it, lol. Does your computer have a code? < -- Bad camshaft position sensor?
Old Mar 29, 2009 | 04:24 AM
duval103's Avatar
duval103
It does. it gives off P1684 and and P0340 (I think) wich is camshaft position sensor. I already looked it up.
Old Mar 29, 2009 | 07:21 AM
darthroush's Avatar
darthroush
Section Moderator
P0340-CAMSHAFT POSITION SENSOR CIRCUIT
When Monitored: Engine cranking/running. Battery voltage greater than 10 volts.
Set Condition: At least 5 seconds or 2.5 engine revolutions have elapsed with crankshaft
position sensor signals present but no camshaft position sensor signal. One Trip Fault.
POSSIBLE CAUSES
INTERMITTENT CRANKSHAFT POSITION SENSOR SIGNAL
INTERMITTENT CAMSHAFT POSITION SENSOR SIGNAL
(K7) 5 VOLT SUPPLY CIRCUIT SHORTED TO GROUND
(K7) 5 VOLT SUPPLY CIRCUIT OPEN
(K7) 5 VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
(K44) CMP SIGNAL CIRCUIT SHORTED GROUND
(K44) CMP SIGNAL CIRCUIT OPEN
(K44) CMP SIGNAL CIRCUIT SHORTED TO VOLTAGE
(K44) CMP SIGNAL SHORTED TO (K7) 5 VOLT SUPPLY CIRCUIT
(K4) SENSOR GROUND CIRCUIT OPEN
PCM - (K7) 5 VOLT SUPPLY
PCM - (K44) CMP SIGNAL
Old Mar 29, 2009 | 07:25 AM
darthroush's Avatar
darthroush
Section Moderator
I have seen two different explanations for P1684, but in your case, I'm assuming it's the one that has to do with the battery being disconnected in the last 50 starts.
Old Mar 30, 2009 | 09:41 AM
duval103's Avatar
duval103
POSSIBLE CAUSES
hmmm. So it could be anyone of these things. I wonder how much repairing wiring problems would cost me. :S thanks for your help!
