What will fit? Wheels?
Old 03-06-2005, 12:04 AM
2K5 Neon's Avatar
2K5 Neon
2K5 Neon is offline
Default What will fit? Wheels?
I have an 05 SXT with the SRT Design package, I am looking to add actual SRT body parts, but first I have to change the factory wheels. I don't mind keeping 15's, but with more offset and a wider/lower profile tire, but the overall circumfrance being the same. I am looking at the ADR Vision, Black, 15x6.5 with 40mm offset and possibly 215/50's or 225/50's. Will this fit? Or does anybody know what will fit without running spacers?
Old 03-06-2005, 02:51 AM
GroundControl's Avatar
GroundControl
GroundControl is offline
Default RE: What will fit? Wheels?
you should be able to fit up to 18 inch rims with thin *** tires. I have 17inch with low profile tires and they fit aliright. I did have to use a weel spacer b/c i got a bigger tire but make sure you get the right tire and you should be fine.
Old 03-06-2005, 06:58 AM
LowSlowNeon's Avatar
LowSlowNeon
LowSlowNeon is offline
Basically what he said. Don't go too wide. I personally wouldn't go any bigger then 17s unless you're just going for a show car. There really is no advantage to having wheels that big.
Old 03-07-2005, 01:51 AM
casper's Avatar
casper
casper is offline
Yeah if you are drivin the car on the street, I would not go any bigger than 17's, really 16's are fine.
Old 03-07-2005, 07:51 PM
2K5 Neon's Avatar
2K5 Neon
2K5 Neon is offline
Will a 16x7 with a 42mm offset fit with 205/50/16 tires? I believe they will, just wondering if anybody has this combo?
Old 03-07-2005, 10:42 PM
casper's Avatar
casper
casper is offline
Sounds about right.
Old 03-08-2005, 08:26 PM
2K5 Neon's Avatar
2K5 Neon
2K5 Neon is offline
what size tires are ok for 17" rims? i know 205/40/17's but are there any others that you guys are running with no spacers and no problems?
Old 03-09-2005, 01:06 PM
jayster05's Avatar
jayster05
jayster05 is offline
I have 17"s with 45's and If I was you I would mabe try the 50's...the neon just has a alot of wheel gap.
Old 03-09-2005, 08:20 PM
2K5 Neon's Avatar
2K5 Neon
2K5 Neon is offline
Jayster, what size 17's are you running? I just went and priced new rims and tires today. Not too bad, ICW Wheels 17x7 and Kumho 711's 205/40/17 for $857.99 out the door. Lugs, mounted and balanced and tax.
Old 03-11-2005, 03:00 AM
Midnight SRT's Avatar
Midnight SRT
Midnight SRT is offline
Nightly Creeper
Dodge Forum Administrator
215/35 ZR 18x7.5 tires (new tires- Dunlap SP Sport FM 901) with 18x7.5 Volt Racing 753 rims. That is the MAX. I have literally no more room.
Quick Reply: What will fit? Wheels?
