help me please
Old May 10, 2009 | 11:49 PM
pyrochin's Avatar
pyrochin
Default help me please
so i got a 2000 dodge neon 117k miles auto trans my car doesnt start
ive changed ingnition coil, pcm, plugs and wires, cam sensor, crank sensor, just redid my timing belt car spins out has fire but will not start i dont know what to do anymore
Old May 11, 2009 | 11:32 AM
jmja9281's Avatar
jmja9281
Try changing out the fuel filter. Hope this helps.
Old May 11, 2009 | 11:44 AM
srt4rez's Avatar
srt4rez
Two things I can tell you to check....make sure you have fuel getting to your engine and check all your fuses too. Also check all your wires, might be due to shortage somewhere. Shoot some starting fluid into the throttle body and see what happens. If it starts and shuts off, then it will be the fuel pump. Good luck and tell us what happened again.
Old May 11, 2009 | 01:51 PM
pyrochin's Avatar
pyrochin
i can hear the fuel pump when i turn the key and my fuel rail has fuel in it as for the filter if you change the filter might as well buy a new pump cause its all 1 piece isnt it? ive tried throttle body spray didnt help car just spins over and back fires out of the intake if i pull a spark plug is has fuel on it and car fires just fine
Old May 11, 2009 | 02:51 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
timing marks right? did it jump a tooth possibly?
i would not worry about the fuel filter.
are u getting fuel, if so what pressure?
Old May 11, 2009 | 05:42 PM
srt4rez's Avatar
srt4rez
Yes, the pump and filter are one piece and I don't think that is the cause. One thing you can do is to reset the PCM...take off the negative battery cable for about 15 secs or so. Also unplug the wires that attach to your PCM and reinstall them again. Be very careful when you are removing the outlets from the PCM...the clips need to be removed and try not to break any plastics in the process. See what happens and let us know on the situation.
Old May 11, 2009 | 08:12 PM
contagious19's Avatar
contagious19
i would say check the timing, same thing happened to me
Old May 12, 2009 | 03:48 AM
pyrochin's Avatar
pyrochin
i know its not the timing i changed the pcm
Old May 12, 2009 | 03:55 AM
pyrochin's Avatar
pyrochin
i need to check the fuel line pressure that im not sure on
Old May 12, 2009 | 05:02 PM
dtjackten's Avatar
dtjackten
did u change the pcm and it is not starting now???? or did u do the belt and now it does not start?
