transmission problems
My son has a 2003 Neon. Transmision blew on Christmas day..Dealer wants $3,000 for a car that has a $1,700 trade in value...Not sure if its worth it to fix, although his car is in new like condition. Babies it...any way, found a 2002 Trani and was wondering if it would fit?
OK, so point out where I said ANYTHING about the 3speed trans used in 1994-2001 neons? the WHOLE conversation was related to the 41TE (aka A604 aka F4AC1) transmission. You bring up something that has NOTHING to do with the topic NOR anything I said in any way shape or form!!!! I've been saying since the start there is NO difference in the OD transmissions since 1989 in how they function, the parts within, operation, etc. There have been a lot of running changes and different case configurations, but the method in which they work has been the same since day one and the ALL use the exact same rebuilt kit (clutches, steels, seals, ring, oil filter, gaskets, speed sensors and much more)
oh and the difference between a 02 and 03 is the final drive ratio, that's it. The TCM has a slight difference in programing. But you can absolutely interchange them.
G'night.
LOL. It has nothing to do with that. It may be the same name for the transmission, 41TE, A604, whichever you'd like to call it, but they are not the same. There were four different A604 units [transmissions] produced. The 2002 and up are 4 speeds, whereas the earlier ones were 3 speeds. There is obviously more to a 4 speed than a 3 speed, therefore, I'm sure that has something to do with the cost to begin with. If they came out with an electronic 6 speed A604, you think the rebuild price will still be the same as a hydraulic, 3 speed since it is still called an "A604?" If you go to different shops ranging from the dealer to private, and get a price for each one and they are not the same for a rebuild, that must be telling you something. Either that, or the whole transmission repair world is scamming every A604-equipped Chrysler owner.
yep you're so right, yep 6 speed 604, yep more expensive to build a 4speed automatic than a 3speed, yep you are the God of neon overdrive transmissions, you taught me a lot about them. thanks for getting me straightend out. I've got to rebuild a 2003 neon automatic trans, can you give me some guidance as to how to do this, I know the minivan automatic overdrive transmissions like the back of my hand and can recite from memory every change done on them and in what years, but I've never done the Neon trans. I hope you can provide me the insite I need to rebuild these unique and special transmissions. Out side of the special Neon 4speed transmission, I know there are over a dozen different minivan overdrive transmissions, however for all of those 4speed transmissions, the interals are all exactly the same and use the same rebuild kit from 1989 - 2007.
In the minivan world, the 3speed trans is called a 31TH(new name) the old name was 413 for the 2.2/2.5 automatic and the 3.0 v-6 as a 670 but both transmissions were identical except the bellhousing. The minivan 4speed trans was called the A604 then in the early 90's it was changed to the 41TE. And if you got the same overdrive 4speed in an Avenger or Talon with the 420 engine, that trans was called a F4AC1 but it was still the same internals as all the other 4speed automatic transmissions
So could you enlighten me as to ALL the unique differences in the 4speed neon transmission so I don't f-up this 2003. I'm willing to listen and learn to an expert such as yourself.
So the 03 neon comes with a 6speed called a 604? How can they have a 4speed and a 6 speed with the same 604 denotation? Are you going to help me with this 03 Neon trans, I know nothing about them and I really want your expertise on how to rebuild it since you say it's so different than the 41TE like what the Minivan's, Dynasty, Shadow, Spirit, Cirrus, Stratus, Avenger, Talon, and Daytona's use. Or atleast tell me what is the difference and I'll figure out the rebuilding part.
