Fuel Filter replacement
Old Oct 14, 2009 | 07:11 PM
mjj1587's Avatar
mjj1587
yeah that or rent a spring compressor... napa has the complete assemblies but almost $200 ea for the front and about $170 ea for the rears... thats nuts.
Old Oct 14, 2009 | 07:31 PM
darthroush's Avatar
darthroush
Section Moderator
Yeah, you can rent the tool. I just made that suggestion since you said you didn't want to deal with it.
Old Oct 23, 2012 | 08:10 PM
arnonefrank13's Avatar
arnonefrank13
u still have to compress it i had to put it on. at leaste i rented it...i did a rear strut ***. monroe 135 bucks....pricey.. it was a bitch to do to.
Old Oct 25, 2012 | 11:37 AM
TejasMtnBiker's Avatar
TejasMtnBiker
I did mine it was easy just use 2 hydraulic jacks and lower the spindle down once the nut is loose on the strut shaft. Just soak all the nuts & bolts with PB Blaster the night before ya do the work it helps. While your that deep in might as well do ball joints & control arm bushings too. Mines a 00' too if and definately needed it all up front.
Spring compressors look way dangerous to me lol If you've ever dropped a coil spring from about 5 feet up and see it blast thru dry wall you might see what I mean
Old Oct 25, 2012 | 05:00 PM
earlyre's Avatar
earlyre
Monroe Quick Struts:
Part #
171580 Front (need 2) $115.89(Rock Auto) $114.50(Amazon)
171578 Rear Left $104.79(RockAuto) $112.87(Amazon)
171579 Rear Right $104.79(Rock Auto) $112.00(Amazon)
Rock Auto Also lists similar Raybestos branded units, nearly identical part numbers (just add a 7 to the beginning-7171580,7171578,7171579) for $86.79 for the rears, $101.99 for the Fronts.
above listed as OE ride quality,
under the "economy" heading on Rock Auto they have Monroe "Econo-matic" Assemblies, again similar Part numbers, just change the 17 out front to an 18(181578,181579,181580) for $60.79 Per Corner.
Link Copied from one of Darth Roush's how-to's
