Engine light came on and the motor sputtered a little bit when accelerate
Old Oct 29, 2009 | 02:32 PM
Dodge4NEON04's Avatar
Dodge4NEON04
Exclamation Engine light came on and the motor sputtered a little bit when accelerate
i have a 2004 4 door dodge neon and last night when i got off work around 9pm i got in my car and tried to start it and it took it a second to start (never has done that before) and the check engine light came on. well i pulled out of the parking lot and when i pressed the gas to accelerate it began to miss and sputter like the car was trying to shut off. so i pulled over to call someone and i turned the car back on and it had no trouble starting that time and it stopped the sputtering but the engine light was still on. so this morning around noon i went to see if it would start and it started right up but the light is still on!!! i have no clue what may be wrong with it , if any EXPERIENCED mechanics would know what would be the problem PLEASE email me at LiveYourLife304@aim.com or just reply back on here... thanx
Old Oct 29, 2009 | 04:50 PM
LowSlowNeon's Avatar
LowSlowNeon
Post the cel (check engine light) codes. You can pull them yourself by turning your key on-off-on-off and then back on. By turning the key on I mean like just the ignition, don't actually start the vehicle up. It should flash the numbers on your speedometer and then it will say "DONE" when there are no more codes. Post what it comes up with. If you can't get it do that then go to Autozone or an auto place and have them tell you what codes your car is throwing. I'm sure someone will have an idea once you post the codes. Good luck.
Old Oct 29, 2009 | 04:51 PM
darthroush's Avatar
darthroush
Section Moderator
Pull the code...
Turn the key from the off position to the on position three times quickly, ending in the on position, and your odometer should say "done," followed by any codes.
Old Oct 30, 2009 | 10:55 AM
Dodge4NEON04
ok i did what u said and i cam up with 2 different numbers
the numbers were 0522 and 0340
anymore info just let me kno
please and thanx
Old Oct 30, 2009 | 11:48 AM
neisg1's Avatar
neisg1
Trouble code P0522 means: Engine Oil Pressure Sensor/Switch Circuit Low Input
Trouble code P0340 means: No camshaft sensor signal at pcm.
P0522 is what caused by either your camshaft sensor is on it’s way out or you have a bad connection in the wiring somewhere. When this code comes up the engine goes into limp/home and will run very rich but will get you home.
Code P0340 can be oil pressure to low, more likely a bad sender unit, or in this case may have been set because the engine was stumbling and not maintaining a constant oil pressure.
Check the connectors on the cam sensor, you could also hook a oil pressure gauge to the oil sender fitting to check the pressure.
If it were mine, I would reset the computer by either disconnecting the battery or with and OBD11 scanner. Then see if the codes come back.
Old Oct 30, 2009 | 01:16 PM
Dodge4NEON04
thanx i appreciate ur advice i will get in done asap
how soon should i get it done??
Old Oct 31, 2009 | 12:58 PM
neisg1's Avatar
neisg1
Is it running normal now? Is the oil light off?
It's always best to check sooner than later, particularly the oil pressure to avoid possible engine damage.
Old Oct 31, 2009 | 02:08 PM
Dodge4NEON04
as of now yes it is running good
but yesterday when i left my girl friends house it acted liked it didnt wanna start but it finally did and the light came back on and sputtered for about 3 seconds and the light stayed on for about an hour and went back off and now its running fine again??
