Just bought a 2000 neno
Old Jan 12, 2010 | 12:37 AM
The Black Stig's Avatar
The Black Stig
Default Just bought a 2000 neno
Thats right pround new owner.
197k
5 Speed
Drives Good!
Questions.
1. Short through shifter, Which one? Is the ones ebay Okay?
2. Is the Shift **** a Screw on?
3. Smaller sterring wheel? WTB, And How to install (I'm 6'5 adn 280lbs it's alil in the way)
4. What do you think of this catback? http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
5. I order a repair manual for my car, but in any case what should be change? I plan on spark plug and wires + trans fuild(What and how much), I Will ask the guy I'm getting it from for clutch fuild flush.
6. I paid 1250 for Good deal? the car looks fansatic for it's age an miles
I was told that it was a lot of high was mostly high way miles.
(Pics).
http://claspics.com/346/264381/12627...JPG.php#browse
I Will be swapping capret pretty soon and getting seat covers and some good ruber floor mats so It will be looking real new on the inside soon
Old Jan 12, 2010 | 08:04 AM
The Black Stig
Moring Bump, and yes i know i spelled Neon it wrong
Old Jan 12, 2010 | 02:59 PM
Captansavaho's Avatar
Captansavaho
1. maddog STS best way to go = http://www.maddogsts.com/
2.think its held on by a hex screw on the side of the shifter head
3.not sure about the steering wheel..get a nice quick disconnect sparco!
4. try a local shop..got my exhaust done form catback for 200 with 2.5" piping and dual tips..look around...but thats not a bad choice either
5.do you know what has already been changed/replaced..timing belt and stuff like that
Old Jan 13, 2010 | 02:27 AM
The Black Stig
T/y
I'd take i need a sterring wheel puller right?....Agh....
4. try a local shop..got my exhaust done form catback for 200 with 2.5" piping and dual tips..look around...but thats not a bad choice either.
Not around here shops are crazy expensive.
Not really I plan to replace alot of stuff because of themiles.... And you mean timing chain right DO i really need to reaplce that? Any good place to get a good Ring set?
Read the quote.
Old Jan 13, 2010 | 02:42 AM
darthroush's Avatar
darthroush
Section Moderator
Have you looked around using Search Tempest for a used, but good quality exhaust? Just because it's used doesn't make it bad.
Yes, the timing belt really needs to be replaced at the correct mileage. If not, you will be doing an entire top end engine rebuild when it breaks.
Old Jan 13, 2010 | 03:25 AM
The Black Stig
I will look into the belt.
Honesty I don't do used parts.... But It looked like a good product in the picture it was stainless and had good welds. I did question the muffler but wth...
If you guys are really saying No I Will look elsewhere...
Is it hard to change the timing BELT? I'm a 12volt tech by trade so....
I'm waiting on my manual and booger bushings so till then...
Old Jan 13, 2010 | 12:18 PM
darthroush's Avatar
darthroush
Section Moderator
I'm not saying no, I'm just getting at there are better options for the price. Your money, your call.
I don't believe the belt to be "hard" to change, just a long process. I know every step to do it, but I am still considering just paying someone to. The one thing that would make it difficult is the timing marks cannot move.
Old Jan 13, 2010 | 01:32 PM
The Black Stig
In theory If you loosen the belt tensioner you should be able to just slip it on... I will just have my friend help me do it, He's a tech at a Chevy dealer plsu he as all the Cool tools
From what I've searched
I need...
A water Pump (Just RTV or should I get the gasket,also will all of the coolant come out too? )
Belt
2004+ tensioner (And i should cut a hole in the plastic for the new one right?)
Engine Struts(are the called something else at auto zone?)
Am I missng something?
Oh and I'm getting refurb fuel injectors too, I talked they guy(he's from ebay). I soaks them in an ultrasonic tub full of solvent(I'm assuming it's ether). And he adds new seals, In either case he told me 17.50 per injecotr and he will give a $20 core exchange too.
Good deal? I seen a few of his pics the look very clean on the port sides, still can tell it was once used but thats a good thing casue that means he's not doctering his pics
Old Jan 13, 2010 | 05:40 PM
darthroush's Avatar
darthroush
Section Moderator
True, it's just getting there that seems to be the pain. I'm not super positive on it as I haven't actually done it yet.
I need...
You have the manual? I'd just follow what it recommends. Looking at the Dodge shop manual, they say to apply di-electric grease to the new o-ring before placing it into position and the way they describe it, it seems it should have a gasket to be used.
Belt
I don't know about upgrading the tensioner, though there is a thread around somewhere about it.
Only need 'em if they are broken. The proper name for them are the upper and lower torque struts. The thing you will want to look at while doing this job is the actual motor mount. It's the one bolted to the frame/body directly across from the timing belt cover. This will be the only time where you can actually see if it is broken or worn or not. Me, even if it weren't broken, I'd replace it. You are in there already, might as well. Better than having to take everything apart again just to replace it later. Removing the mount is like the last step before taking the timing belt cover off. They are less than like $30.
Um, water pump and timing belt kit. Should be it unless you are going to do the mount.
I personally wouldn't mess with the injectors if they work fine. I have heard that Neon injectors shouldn't be cleaned, though some have had it done and they work fine. I don't know about pricing on something like that.
Where are you getting your water pump/timing belt kit from and how much?
Old Jan 13, 2010 | 07:56 PM
The Black Stig
Okay I'm super relived, I found A TON OF matince records in the glove box.
The timing belt was reaplce at 100,000 Miles and then agina a$ 122,868 along with the water pump(whixh is why i'm assuimng it was replaced) and just other stuff.
Overall I'm very happy !!!
