My car with pics
Old Feb 3, 2010 | 09:04 AM
  #21
The Black Stig's Avatar
The Black Stig
Originally Posted by darthroush
I think people usually use a non-fouler for the downstream one. Not sure why the upstream one would do that. No wires melted or anything?
Nothing, it's werid but i think my friend caused it, he couldn't find gears to save his life. I think third gear + flooring it = not good.
I will reset it, and if it happens agian find the issue.
Old Feb 3, 2010 | 03:33 PM
  #22
The Black Stig
okay rest and after a hour round trip it came back on. I will do some resarch on it but what are you guys thinking?
Old Feb 3, 2010 | 03:41 PM
  #23
The Black Stig
Okay research done
The catalytic converter has an oxygen sensor in front and behind it. When the vehicle is warm and running in closed loop mode, the upstream oxygen sensor waveform reading should fluctuate. The downstream O2 sensor reading should be fairly steady. Typically the P0420 code triggers the Check Engine Light if the readings of the two sensors are similar. This is indicative of (among other things) a converter that is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system
So in a nutshell the o2 sensors are doing math and because cat is not sitting in between them anymore the back o2 sensor is cheating off the front one. and they are getting the same answer so now all i have to do it is get rob(aka Mr.resistor) and put him between the too and the back o2 can't cheat anymore
Old Feb 3, 2010 | 04:15 PM
  #24
darthroush's Avatar
darthroush
Section Moderator
That's where people put in the non-fouler as well; the downstream O2 sensor.
Old Feb 3, 2010 | 04:30 PM
  #25
The Black Stig
did the resistor and I'll you know after this Lil road trip I'm taking if it comes back on.
Old Feb 4, 2010 | 03:59 PM
  #26
The Black Stig
Power Wire Redone.
It helped ALOT, less stutter at lower rpm and the engine revs smother as well def the best upgrade I've done so far. I still need to do the Main postive from the alt, I really didn't fill like lifting the car and I was Low on power wire.
Also I couldn't tell if the lights and stuff was dimming(it was light out) but it appeared to be fine Will give a def answer later on tonight.
Old Feb 4, 2010 | 05:40 PM
  #27
darthroush's Avatar
darthroush
Section Moderator
The headlights actually ground to the front radiator support. Check those grounds for headlight issues too.
What's the best place to get that wire from for a decent price? I'm sure stereo shops mark theirs up more because theirs is "better."
Old Feb 4, 2010 | 05:56 PM
  #28
The Black Stig
I got HID's . And I meant the lights inside.
Home depot Thats all two guage wire(1.50 a foot) it is a bit stiff and hard to work with.
I suggest soldier on termnal ends The only place i could find these at were ACE Hardware @ 2$ each(mad) Home depot DOES NOT stock them and yes they are cheaper online.
Also you will want a hack saw to cut up the wire it's just cheaper than the low guage wire cutters.
OH and those battery termanls were found here (CLICK ME) you will need the postive as they are diffrent sizes.
Old Feb 4, 2010 | 06:34 PM
  #29
darthroush's Avatar
darthroush
Section Moderator
For $1.50/ft, I'll take 2-gauge over 1/0! I could probably even afford to do this project sooner than later at that price. I suppose I'll have to learn how to properly solder though. What about clamp-on? I've heard not to use solder-on clamps, but my main reason is I'm not very experienced with soldering --> any solder would work if I do go that route? Either way, they'll have shrink tubing on them as well.
Oh, how many feet did you get...err, use? I've heard 12' should be enough?
Old Feb 5, 2010 | 10:03 AM
  #30
The Black Stig
13 but i would suggest 14/15 I'm about half short to do the main power from the alt.
And it's super easy to solder the ends on. there pretty much like a Lil copper cup. Here's some pics
