Car pulls to the right under light acceleration automatic
#41
#42
#43
Well I wanted to let everyone know I finally found the problem! In the past week the pulling to the right and left on turns got really bad. I jacked left front up to check tie rod again and noticed the lower control arm horizontal pivot bolt was just hanging about to fall out. It seems the Firestone dealer down in San Diego never bothered to put the special nut with large tang on it and torque it down to 120 ft/lbs. When I looked at the bolt head before it was snug and tight against the frame mount but I didnt bother looking up in the recess hole to make sure the nut was on the bolt up in there and just assumed the bolt was torqued to spec. I had to order one from the dealer since its a special.
My daughter then confirmed with me the car starting wandering on turns after Firestone put new control arms on the car, so they obviously left the nut off and the control arm was never tight. So nothing short of ruining the 2 front tires I lucked out the bolt didn't completely fall out while driving causing loss of control and an accident.
Also I noticed at some point Firestone put 1 wrong size tire on the car which wasn't helping front end control either. One tire was a 185-65-15 and one was a 185-60-15. This is exactly why I do all the work on our cars cause you cant trust anyone else to do it right. Now that daughter is done with college and back home I have control of car repairs again.
