Help Installing an Aftermarket Tach!!!
Old Jul 14, 2010 | 12:26 AM
bkennedy1289's Avatar
bkennedy1289
Default Help Installing an Aftermarket Tach!!!
I have a 2000 Dodge Neon Highline, 5-spd manual, and NO TACH!?!? So I purchased a Sunpro Supertach II. It says it isn't supported on the one page included, however, i have been reading that it is possible... I heard that wiring it to a wire in or coming from the PCM and wiring the backlight to the dimmer switch are the ways to go.. So TWO(2) questions.. 1) Which PCM wire should i wire it to?? and 2)Where on or what wire with the dimmer switch would be best place to wire the backlight to?? Thanks for the help.
Old Jul 14, 2010 | 12:40 AM
bkennedy1289
I understand that an adapter would work... However, i heard you don't need it... this is a quote from a post on a different forum from 2003 and the guy never posted anything...
"just had a sunpro super tach II installed, 2.5", and it was running slow at 1st. i could mash the peddal down & let her wind up 2 7000rpm+tach wood
max out at 3000rpm/atx. my mechanic ran 1 of the wires directly 2 my pcm
instead of the coil pack the tach is very responsive and completely accurate
if u want 2 know about this pcm 'coil bypass' hook up i can post which pcm wire u gotta hook up 2 on monday nite after i ask my tech. i guess it is also easier 2 do it this way so he sez"
Old Jul 14, 2010 | 12:54 AM
sapporo's Avatar
sapporo
check sunpro's web site. I had a tach sunpro tach that has dip switches they told me how to make it work on a 3.3 (many years ago)
Old Jul 14, 2010 | 01:29 AM
bkennedy1289
I sent them an email, hopefully they can help. However, their compatibility paper said that the tach isn't supported, so idk if they will be able to help me.
Old Jul 16, 2010 | 03:13 PM
bkennedy1289
They just told me to buy a Super Tach III... So Idk if you can do it, I'm sure there may be a way u can rig it. I just went and got the new tach.
Old Jul 16, 2010 | 03:17 PM
darthroush's Avatar
darthroush
Section Moderator
That's why you check to make sure something will work on your car before you buy it.
Old Aug 26, 2010 | 02:31 AM
neonftw87's Avatar
neonftw87
yep, on the old neons you could wire it straight to the PCM and it be accurate.. but not the 2000+ for some reason... you ahve to get a tach adapter to make it work.. all it does is amplify the signal coming from your coil.
neonftw87's Avatar
neonftw87
ive been through this.. i feel your pain lol
