Clutch problem :(
Old Oct 30, 2010 | 02:30 PM
Nicholas_Scott's Avatar
Nicholas_Scott
Default Clutch problem :(
Hey guys, Last night I was driving and pressed on my clutch pedal and it slid to the floor almost but still had an half inch to actually shift and drive still with no grinding, But I had to drive and rev really slow otherwise i wouldnt go anywhere. I noticed I can pull the pedal up by my finger but that still doesnt disengage the clutch all the way. Cable is still intact from what I saw last night. any ideas?
2000,neon
Old Oct 30, 2010 | 02:50 PM
hemi4spd's Avatar
hemi4spd
ummm cable? the 2nd gennies have a hydraulic clutch. maybe your out of fluid???
Old Oct 30, 2010 | 04:33 PM
TheSwann's Avatar
TheSwann
i had the opposite problem on mine, clutch action was working fine but when i would go to shift it wouldnt be engaged. ended up replacing both the slave and master cylinders and running all new hydraulic lines (round 85k miles or so). was not fun to bleed those things.
Old Oct 30, 2010 | 06:21 PM
Nicholas_Scott
Nah my car runs straight cable no hydraulic on mine dude my car has 128,000 on it. No idea if the clutch was replaced.
Old Oct 30, 2010 | 06:54 PM
hemi4spd's Avatar
hemi4spd
problem is most likely in the release bearing/clutch fork assembly, or all the release fingers have worn off and the bearing has passed thru the clutch cover and is directly contacting pressure plate.
But these situations would be rather noisy and you claim yours is quiet. ??
Cable strecthed maybe?
Oh and if you do need a clutch buy the Luk kit as u'll get the most miles outta it compared to the aftermarket clutches
Old Oct 30, 2010 | 07:16 PM
Nicholas_Scott
Mine was pretty quiet but I did notice sometimes when I released the clutch I heard it clash or just closing etc..cable could have stretched but its only a year old..but it is an aftermarket cable.if its the release bearings and fork is that expensive to fix? I have no idea. :P
Old Oct 31, 2010 | 03:23 AM
hemi4spd's Avatar
hemi4spd
parts not too much but trans would have to be removed.
if I remember right i did my clutch, release bearing, pressureplate for under 400 canadian dollars.
took the better part of a saturday to do.
Old Oct 31, 2010 | 04:03 PM
Nicholas_Scott
why would my transmission have to be taken out? clutch is seperated from that. isn't it?
Old Nov 2, 2010 | 09:07 PM
hemi4spd's Avatar
hemi4spd
clutch and release bearing are sandwidched between the 2 units
think of the engine and the transmission as the biscuit and the clutch as the cream in the oreo cookie
Old Nov 3, 2010 | 02:42 PM
Nicholas_Scott
Gotcha little update, Brought my car to my local mechanic said he thinks the cable just stretched. so today I purchased OEM cable from moparpartsamerica.com. any of you guys ever bought things from them? wish me luck! ha
