2005 Dodge Neon SXT - Idle slowly drops to 550 RPM
Old Oct 8, 2013 | 05:25 PM
  #21
dodge_neon_man's Avatar
dodge_neon_man
i am putting in new O2 sensor. i cant get the wire disconnected. any one know how to get this off. im going to rent a O2 sensor wrench
Old Oct 9, 2013 | 12:03 AM
  #22
frankarnone70's Avatar
frankarnone70
Either way my old alternatives bearings were about to seize. And I could pull the spark plug tube out of the head with my fingers. . When I got the car every time I went to stop my idle dropped to 500 elms and would almost die. I replaced th alternator with a used one and re seated the spark tubes. Problem solved. And I'm still running with the plug wires that came with the car. I just speak from experience with my neon s and try to help others.
Old Oct 12, 2013 | 03:40 PM
  #23
jaye944's Avatar
jaye944
No harm, no foul !
Were all on here with best advise and expereince that we have gained,
My expereince is Ford's and Porsches for 20 years and more Car forums than I can remember. Trying to help diagnose a persons issue is like calling a doctor, they'll tell you to come in and even then no 2 people are the same.
And these forums as you correctly say are all about helping others, which is what we all try to do.
Old Oct 12, 2013 | 03:42 PM
  #24
jaye944's Avatar
jaye944
4 sure you'll need an o2 wrench, soak it before hand (at least 3 hours) with a good penetrating oil such as WD40
Old Oct 13, 2013 | 05:53 PM
  #25
darthroush's Avatar
darthroush
Section Moderator
Originally Posted by jaye944
4 sure you'll need an o2 wrench, soak it before hand (at least 3 hours) with a good penetrating oil such as PB Blaster
Fixed it for you WD-40 isn't formulated to be a full-on penetrating spray like PB. PB Blaster is formulated as such (so it works better and faster), and is one of the best in existence.
Old Nov 25, 2013 | 11:15 PM
  #26
dodge_neon_man
i have done all that. still runs rough in gear sitting stil. now this morning went to start the car started but i put it in drive and almost died then i went to back up it died and couldnt get it started for like 1/2 hour then it started. it will crank over and sounds like it wasnt to start but did. is it the coil pack?
Old Aug 3, 2014 | 01:03 PM
  #27
mannyg26's Avatar
mannyg26
Default 500 rpm
Hi. I bougth a 2005 neon few weeks ago. Its stay normally at 500 RPM and goes to 700 or 800 RPM with A/C on. I did change already spark plugs, oil filter. My big concern is. When I search for MPG says it should run around 24 or 26 mpg so 300 miles per tank aprox. I have fill the tank already 3 times and its running around 200 mile per tank that's mean between 16 mpg that's bad. Please I need an advise on this. Otherwise I might be thinking on sell it. Thing that I wish not because I like the car looks pretty with the body kit.
Please any advise.
Thank you so much
Manny
Old Oct 4, 2015 | 08:00 PM
  #28
70383roadrunner's Avatar
70383roadrunner
Believe it or not my mechanic says the best he has found is the Mopar stuff.
Old Oct 5, 2015 | 02:40 PM
  #29
TejasMtnBiker's Avatar
TejasMtnBiker
I know their mopar dry silicone spray does wonders for the dry sticking door hinges
Old Oct 10, 2015 | 02:25 PM
  #30
darthroush's Avatar
darthroush
Section Moderator
That might be AeroKroil? I know Ford uses it. It is pricey, but seems to be the best stuff ever made, lol.
