Help help help 2001 neon
Old Nov 25, 2010 | 12:33 PM
roberto1990's Avatar
roberto1990
Default Help help help 2001 neon
Hello im new to this forum.I have a automatic 2001 dodge neon i was stoped at a light and the car just turned off and it wouldnt turn back over. The cluster where the mileage are at on top it says fuse i checked all the fuses and they are all good also when you do try to turn it on it doesnt do anything the started doesnt come on or the fuel pump battery is good has the right voltage i also replaced the neutral safety switch that is located in front of the transmission and nothing so if anyone has any idea of what it could be i would really appreciate it.
Thanks
Old Nov 25, 2010 | 12:45 PM
showsxt's Avatar
showsxt
This happened to my sxt like 2 or 3 yrs ago and my dad came over and we found a fuse relay in the engine bay was bad try those if you havent yet.
Old Nov 25, 2010 | 01:04 PM
roberto1990
i just took the horn relay and swished them with all of them and nothing
Old Nov 26, 2010 | 01:05 AM
hemi4spd's Avatar
hemi4spd
when this happens do you still have lights?
Old Nov 26, 2010 | 10:42 PM
roberto1990
yes i still have lights
Old Nov 27, 2010 | 01:47 PM
roberto1990
anyone????
Old Nov 27, 2010 | 02:24 PM
darthroush's Avatar
darthroush
Section Moderator
Corroded/loose/disconnected ground in the engine bay?
Old Nov 30, 2010 | 11:28 PM
hemi4spd's Avatar
hemi4spd
ive seen corrosion on the backside of the PDC under the hood, get a multimeter and start testing.
now when you say fuses are good are u just visually klooking at them or are you testing for power on both sides of the fuses?
Old Dec 6, 2010 | 06:49 PM
ryderrolle's Avatar
ryderrolle
did you hit a bump or hole? I have a 01 neon and anytime i hit a speed bump or hole I blow my main relay fuse which is loctade on the side of the dash. Enigine, and fuel pump shuts off but I still have the dash cluster, radio and lights
Old Dec 6, 2010 | 10:11 PM
Moparkyle's Avatar
Moparkyle
Sounds like a crank position sensor. More details may be helpful. How far did you drive the car? What temp was it outside? Any codes stored?
