'Hey there' from new member...
Old 01-02-2011, 02:36 PM
Takin' Checkers's Avatar
Takin' Checkers
Takin' Checkers is offline
Default 'Hey there' from new member...
I've just joined the forum. Been reading threads for the past 2 hours or so...lots of great info...thanks!
I don't have a dd neon but race an '03 Neon stock car at local 1/4 and 1/3 mile tracks. Been racin for a few years now. Learnin as I go and as I rip apart & rebuild.
Anybody know where I could get a detailed set of wiring diagrams for my '03 neon? I have the Haynes manual but can be misleading/not very detailed regarding wiring. I need it mainly for the cluster wires...wanna figure out which wire is for the tach signal?? On 95-99 its the light grey with light blue stripe wire but is not included in the '03 wire harness.
If I can't figure it out I'll need a converter for the ign coil.
Appreciate any advice!
Old 01-02-2011, 02:41 PM
whtdoesitmatter's Avatar
whtdoesitmatter
whtdoesitmatter is offline
that tachs gonna cost you alot,
http://www.modernperformance.com/tac...er-p-1141.html
or
http://www.modernperformance.com/tac...er-p-1142.html
depending on your setup, i've tried splicing into the wires going to the coil pack, i think one will give you half readings, another half readings and the other no reading and when you try to use the two half reading wires you miss fire like crazy
Old 01-02-2011, 02:55 PM
Takin' Checkers
yeah, I've tried that before on an old gen neon race car. The rpm needle jumped all over the dial...not accurate. Another racing buddy told me he picked up a converter to connect to the ign coil for about $150 on Jegs I think.
Old 01-02-2011, 02:57 PM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
the cluster WD is broken down into 2 diagrams
heres #1
http://
and heres #2
http://
Old 01-02-2011, 02:59 PM
Takin' Checkers
That should help a lot, thanks!
I'll take a closer look at it and find the tach signal wire sig wire...if it's there that is.
Old 01-02-2011, 03:02 PM
Takin' Checkers
Am I staring right at it like a fool, or does the diagram not indicate what wire is the tach signal?
Old 01-02-2011, 03:03 PM
whtdoesitmatter
yeah without the converter even when you splice into the signal wires you wont get the right reading, i've tried it and so have a bunch of other members on here, when doing so there is a 3 wire clip into your coil, thats where the 03-05 sensors read from, if u try to hook the tach directly up to any combo of those wires you will get 2 half reading combos(around 4k rpms redline it will read) and 1 no reading combo and one combo that miss fires your engine
Old 01-02-2011, 03:04 PM
Takin' Checkers
fyi, the car that the engine came out of had a tach in the original cluster.
Old 01-02-2011, 03:07 PM
Takin' Checkers
Have you ever tried it out on an old gen neon? My tach worked with a straight hook up to the harness wire (1997 neon)
Old 01-02-2011, 04:51 PM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
The cluster spedometer, Tach, and ECT gagues are positioned using PCI BUS messages from the PCM. so no independant tach signal
also i guess thats why you need some expensive module
Quick Reply: 'Hey there' from new member...
