Low idle when stopped in drive
Old Feb 13, 2011 | 12:18 AM
gcretro's Avatar
gcretro
Default Low idle when stopped in drive
04 Neon, 102K.
When stopped at a red light in drive, I can feel the rpm drop. It's hasn't died anytime yet. I can't tell the rpm since mine has no tach. I shift to neutral and I can feel the rpm go up.
I have cleaned the TB, IAC, MAF, changed air filter and seafoamed. I am going to change plugs tomorrow.
Any other pointers?
There was some talk about some adjustment in the throttle body, what is that?
Old Feb 13, 2011 | 04:42 AM
darthroush's Avatar
darthroush
Section Moderator
An auto ALWAYS idles lower in gear. Problem solved.
Old Feb 14, 2011 | 01:30 PM
Moparkyle's Avatar
Moparkyle
Your car is operating normally.
Old Feb 15, 2011 | 10:48 AM
gcretro's Avatar
gcretro
Well the idle seems to drop pretty low and I feel greater vibrations on the steering as though the motor is stumbling.
I'll borrow an OBD2 gauge one of these days and see what the rpm drops to.
Old Feb 15, 2011 | 01:10 PM
darthroush's Avatar
darthroush
Section Moderator
Did the new plugs and wires help?
Old Feb 15, 2011 | 04:24 PM
gcretro's Avatar
gcretro
Nope just plugs I didn't change wires..., I put new NGK V-powers. (There were cheap about 7 bucks after discount at advance auto online order. Wires might be more I guessed.)
No noticeable difference.
What's that throttle body adjustment screw some folks have talked about? Just curious.
Old Feb 15, 2011 | 04:26 PM
darthroush's Avatar
darthroush
Section Moderator
How old are the wires? They should be replaced about every 60,000 miles (every other plug change).
Most auto's don't have that screw, but it allows you to adjust your idle.
Old Feb 15, 2011 | 10:31 PM
TaterTodd's Avatar
TaterTodd
I've changed the wires at every tune up .. when the plugs change the wires get changed also. But that's just me, I've done this to every car I've owned. I guess you could say it's a personal preference. I'm a bit off like this ...
Old Feb 16, 2011 | 12:07 AM
showsxt's Avatar
showsxt
My auto only does that when she needs new plugs and wires so change the wires and your problem should be fixed.
Old Feb 16, 2011 | 09:46 AM
AnthemBassMan's Avatar
AnthemBassMan
-Mine idles about 550 rpm when sitting at a stop light while in drive. If I put it in neutral, it will go up to around 700 rpm. Never had any issues with it dying or sputtering, just a smooth idle at stops. Right now I have NGK G-Power plugs in it.
L8R,
Matt
