NGC question
Old 02-22-2011, 05:18 PM
bmc2004's Avatar
bmc2004
bmc2004 is offline
Default NGC question
i went to a dodge dealership today and asked about getting my r/t reflashed. He said it makes the car drive better and the software updates are just a good thing to do. I've always wanted a performance chip though. Do i have to reflash my car before getting a chip or can i reflash it and down the line get a chip put in. Does the NGC prevent a chip from being put in unless you reflash it?
Old 02-22-2011, 05:55 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
A chip won't do anything either way. I just can't stand Dodge and all of these "updates" they have to perform to get the cars to run correctly.
Old 02-22-2011, 06:36 PM
showsxt's Avatar
showsxt
showsxt is offline
i would only have your r/t reflashed if you have all kinds of engine mods like I do and Im doing a turbo setup soon also . Chips are crap in 4 cylinders all other cylinders they do well in.
Old 02-23-2011, 05:07 PM
AnthemBassMan's Avatar
AnthemBassMan
AnthemBassMan is offline
-What are these flashes for? I saw on the computer or module by the radiator on mine, it says something like "software version 05/2005." Or at least something close to that. Are there newer updates for this?
L8R,
Matt
Old 02-23-2011, 07:16 PM
darthroush's Avatar
darthroush
Section Moderator
To make the car work the way it should.
Old 02-23-2011, 07:31 PM
showsxt's Avatar
showsxt
showsxt is offline
Yes indeed well worth it not much for having your 03-05 updated actually reflashed.
Old 02-24-2011, 11:10 PM
gcretro's Avatar
gcretro
gcretro is offline
Whats that? worth it or not? I have an 04 Neon SE.
Are there newer updates to the firmware? (and whats the cost to get these done ?)
Old 02-24-2011, 11:31 PM
darthroush's Avatar
darthroush
Section Moderator
Your VIN needs to be run to check for an update. Cost depends on the place.
Old 02-25-2011, 09:43 AM
showsxt's Avatar
showsxt
showsxt is offline
Only cost me 50bucks to have my 04 sxt reflashed someplaces are more expensive though.
Old 03-10-2011, 10:41 PM
gcretro's Avatar
gcretro
gcretro is offline
So my 04 Neon, does anyone here have the ability to check if it has a PCM update available / due?
Edit: removed the vin.
tHX
Quick Reply: NGC question
