2003 Dodge Neon Oil Pressure Sensor Torque?
Old Nov 17, 2011 | 04:42 PM
buddhaman's Avatar
buddhaman
Remove the heater core hoses next to the engine and get the socket for it. Autozone has it unless you already have a 1 1/16" deep well. Are you putting in a new sending unit or going the gauge route?
Old Nov 17, 2011 | 07:43 PM
darthroush's Avatar
darthroush
Section Moderator
I just reached in over the top of the valve cover. It all depends what's easiest for you.
Old Nov 17, 2011 | 09:27 PM
buddhaman's Avatar
buddhaman
I also removed the battery which made it easier to get a feel for the thing plus it's always good to disconnect the battery when you're switching sensors.. I tried over the valve cover but that didn't work too well for me.
Old Nov 20, 2011 | 12:42 PM
03neonken's Avatar
03neonken
Thanks guys! I'm going to work on it today. I'll just remove the hood for ease of access. I just bought a replacement sending unit since I don't have much time to do the other stuff.
Thanks for all the help and responsiveness, and I'll be back to let you know how it went.
-Kenneth
Old Nov 22, 2011 | 09:19 PM
03neonken's Avatar
03neonken
Hey guys, SUCCESS! I was able to replace the sensor over the weekend... Monday goes by, no issues. Today, the damn warning light comes on again.
So here's the back story.
Oil Pressure warning light keeps coming on, so I did an engine flush (twice) and replaced oil and filter. That did not fix the problem. Then I replaced the sending unit, worked for one day and the light is back on.
I just called my local AAMCO repair shop and they said they will charge between $150 to $250 just to do a diagnostic.
What would you all recommend? Should I just go right ahead and replace the oil pump?
Thanks for all the feedback.
-Kenneth
Old Nov 23, 2011 | 04:45 PM
darthroush's Avatar
darthroush
Section Moderator
What exactly was this "engine flush?"
Old Nov 23, 2011 | 05:50 PM
03neonken's Avatar
03neonken
It was the "Gunk" brand motor flush.
Old Nov 23, 2011 | 09:18 PM
buddhaman's Avatar
buddhaman
Instead of spending that much just put a mechanical gauge instead of the sensor. Doing that will tell you how much pressure you have vs a dummy light. That's a big reason I just did it that way.
Old Nov 23, 2011 | 11:34 PM
03neonken's Avatar
03neonken
What is the total cost to do that?
Old Nov 24, 2011 | 01:32 AM
darthroush's Avatar
darthroush
Section Moderator
Gauge kit plus pod plus the time to install it.
