gas gauge going funky..
Old May 2, 2011 | 08:51 PM
buddhaman's Avatar
buddhaman
Default gas gauge going funky..
i had to fill up my car today and it was right at the beginning of the red line for "E" and it only took a little over 9 gallons to fill up. is this a common issue or do i need to replace my sending unit?
Old May 2, 2011 | 09:19 PM
AnthemBassMan's Avatar
AnthemBassMan
-I'd say kind of typical. Mine usually takes barely 10 gallons once the low fuel warning lights up.
L8R,
Matt
Old May 2, 2011 | 10:26 PM
buddhaman's Avatar
buddhaman
idk if i should just keep a gas can in the trunk and drive it til it gets to the "E" and see if i can still drive after that or what. if it is being funky then i'm calculating my mileage wrong.
Old May 3, 2011 | 01:50 AM
darthroush's Avatar
darthroush
Section Moderator
Why do you think this is a problem? It's a 12 gallon tank with a reserve being part of that 12.
Old May 3, 2011 | 05:58 AM
buddhaman's Avatar
buddhaman
how big is the reserve? the reason i was asking is because i've been trying to figure out my mpg's and that kinda screwed it up i think.
Old May 3, 2011 | 08:38 AM
leprechaun1874's Avatar
leprechaun1874
How is it screwing you up? Take the number of miles driven/gallons of fuel put in tank= mpg. It doesn't matter what the gauge says.
Old May 3, 2011 | 09:18 AM
AnthemBassMan
-Yep, always go by how much gas you actually put in the tank.
L8R,
Matt
Old May 3, 2011 | 10:03 AM
buddhaman's Avatar
buddhaman
yeah that makes sense. my brain is only half working lol
Old May 3, 2011 | 12:13 PM
darthroush's Avatar
darthroush
Section Moderator
There is usually a 2 gallon reserve or so on most cars. If I just get to the end of E, I get just about 10 gallons in the tank.
Old May 3, 2011 | 02:07 PM
buddhaman's Avatar
buddhaman
oh ok. that makes sense why that doesn't show up on the gauge.
