srt-swap
Old May 14, 2011 | 10:24 AM
superman93's Avatar
superman93
well im looking to kit a whole kit they look cheeper then buying every little part... so is their anyway to keep the stock engine n trany on or would i have to change it
Old May 14, 2011 | 10:25 AM
showsxt's Avatar
showsxt
But what would be the fun of buying a srt4 when you can build your own turbo neon get more wows out of that.
Old May 15, 2011 | 03:29 AM
darthroush's Avatar
darthroush
Section Moderator
If you buy a kit for your car, you can keep what you've got.
Old May 16, 2011 | 11:50 AM
bmc2004's Avatar
bmc2004
I actually have a friend that swapped an srt-4 engine into an sxt. He bought a totaled srt-4 ( just wrecked in the back) for 3 grand. Then he pulled the transmission and motor and harness and ecu and did the work himself. He also menthanol injected it and its so sweet. But it would cost a lot more if you couldnt do it yourself. Plus you always run the risk of buying an engine that was run hard or a tranny the same. I would like to do it this summer but well see.
Old May 16, 2011 | 01:13 PM
showsxt's Avatar
showsxt
Im thinking about going the way dt did just buying the same turbo setup as him seeing there are alot of abused srts and pts around I have found out.
Old May 16, 2011 | 05:27 PM
superman93's Avatar
superman93
so if i bought this
http://cgi.ebay.com/ebaymotors/HUGE-...Q5fAccessories
i can leave everything the way i have it?
Old May 16, 2011 | 06:35 PM
hemi4spd's Avatar
hemi4spd
that kit will require some custom fabrication to get to work.
800 in parts
$$$$ labour and reinventing the wheel
Old May 16, 2011 | 10:56 PM
superman93's Avatar
superman93
ok thanks any one know how to add little more hp n what the best n cheapest way to drop?
Old May 17, 2011 | 08:14 AM
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
I assure you that you can get plenty of "wows" modding an SRT.
Old May 17, 2011 | 12:26 PM
showsxt's Avatar
showsxt
Yeah but you get alot more wows if you have a sxt or r/t or a 1st gen turboed that you built yourself instead of buying a srt4 thats already turboed from factory and you have alot more fun also doing so.
