Aftermarket fuel pump
Old Jun 2, 2011 | 10:06 PM
buddhaman's Avatar
buddhaman
Question Aftermarket fuel pump
Who makes a fuel pump that doesn't have a filter attached to it that will work for our cars? Another thread got me thinking about this but I didn't want to hijack it. I'm thinking of putting a new pump in and then doing an in line fuel filter.
Old Jun 2, 2011 | 10:54 PM
darthroush's Avatar
darthroush
Section Moderator
All fuel pumps have a filter/screen on them. There is the main filter on these cars that can be changed fairly quickly, depending on your experience with them.
Old Jun 2, 2011 | 11:20 PM
buddhaman's Avatar
buddhaman
Do you mean the filter that's attached to the pump when you say main filter? If so, I've never done a fuel pump on any car.
Old Jun 3, 2011 | 12:02 AM
darthroush's Avatar
darthroush
Section Moderator
No, that's the screen-type filter. There's a serviceable filter (a "real" filter) on the top of the fuel pump assembly.
Old Jun 4, 2011 | 01:54 PM
chronoboy's Avatar
chronoboy
the filter he is talking about is called a fuel pressure regulator/fuel filter, i replaced mine awhile back and it was almost a 100$ if i remember right, it was right after i bought the car, so it might be more now.
Old Jun 4, 2011 | 02:05 PM
chronoboy's Avatar
chronoboy
and i got a question, how can you tell if they are getting clogged? anyway without takeing it off and blowing through it? i have a buddy with another 03 neon sxt manual and it bogs in low rpms take a bit for it to start picking up, and he put new plugs and wires in, only thing i can think of is that when we where camping he ran out of gas and was drunk and took a dirty jug and syphoned gas out of my truck and put it in his car i'd say a little over a gallon worth so i was thinking that maybe that dirty gas could of clogged up that filter a bit, but dont want to jack up his car and crawl under if this is not the problem.
Old Jun 5, 2011 | 01:45 AM
darthroush's Avatar
darthroush
Section Moderator
The filter is like $30 at Dodgeparts.com. Not too much difference from many OEM replacement filters.
Old Jun 5, 2011 | 05:48 PM
chronoboy's Avatar
chronoboy
so is that the whole fuel pressure regulator or just like a new filter you replace in your old one?
Old Jun 6, 2011 | 04:43 AM
darthroush's Avatar
darthroush
Section Moderator
New filter. There was originally a misprint by Dodge that said the whole assembly had to be replaced, but it does not. It is on the outside of the tank, but still by the pump assembly.
