2000 neon bogging, misfire and back fire through intake
Old Jun 10, 2011 | 03:11 PM
Hef88's Avatar
Hef88
Default 2000 neon bogging, misfire and back fire through intake
check engine light came on with a 0301 code cylinder #1 misfire. It is bogging down at low rpm and back firing through intake but once speeds are above 40 and rpms are up it stops. I replaced plugs and plug tube gaskets due to oil leak and valve cover gasket. swapped plug wires and cleaned injectors and moved their position to see if misfire moves to another cylinder, no new engine codes but engine is still having same problem. it is intermittent but frequent. it also does it at idle. you can hear a miss out of the exhaust but no pattern to it, sometimes 2 in a row sometimes 3 and then none for a while. Any help would be greatly appreciated thanks
Old Jun 10, 2011 | 04:22 PM
darthroush's Avatar
darthroush
Section Moderator
You've replaced the spark plugs and moved the wires and injectors and the misfire is still on cylinder 1. Going "upstream" from those, is the coil pack and its wiring.
Old Jun 10, 2011 | 04:57 PM
hemi4spd's Avatar
hemi4spd
if the coil checks out perhaps its fuel delivery, maybe #1 injector?
I would say possible burnt valve but that wouldnt be intermittent.
Old Jun 10, 2011 | 05:34 PM
Hef88's Avatar
Hef88
How do I check the coil pack for faults
Old Jun 10, 2011 | 05:52 PM
Hef88's Avatar
Hef88
its also less noticeable when I ease into the throttle. The check engine light hasn't come on again ever since I reset it but I'm assuming it needs miles on it to go through diagnostics. So I don't know yet if it still on cylinder #1
Old Jun 10, 2011 | 11:37 PM
hemi4spd's Avatar
hemi4spd
ull need a volt meter set to OHMS
funny thing about coils is they can test fine but can break down with heat or vibration and be intermittent
how to test
http://i55.tinypic.com/2d11onl.jpg
Old Jun 11, 2011 | 01:00 PM
Moparkyle's Avatar
Moparkyle
I would have to say do a compression test and leak down test.
Old Jun 13, 2011 | 02:06 PM
Hef88's Avatar
Hef88
Thanks for all the info, I will test the coil first. Hopefully it tells me something, the problem is getting worse and going to higher rpms so if it is the coil pack I will be happy because that is not too expensive. Compression test I will do after, not hard to fix blown head gasket or burnt valves just dont want to get into such a job on a car that is needed daily. Again thanks for all the info, I will let you all know what I find
