Cold Air Intake
Old Jul 8, 2011 | 10:29 PM
emericaman's Avatar
emericaman
i just put mine on last week and i am getting 34mpg in my 02. not sure what i was getting before that though.. i figure 32-33mpg. it has always been good on gas though.
Old Jul 9, 2011 | 03:28 PM
TaterTodd's Avatar
TaterTodd
Without a C.A.I. in the city i'm getting 34mpg's and on the HWY I'm pulling 40mpgs ... regular tune ups and take it easy on the throttle and you can get the mileage your looking for.
Old Jul 9, 2011 | 03:41 PM
showsxt's Avatar
showsxt
Yes have had an ebay intake on for almost 7yrs and have had the same gas mileage has tater with him not having a intake and mines an auto and has over 210,000 miles on her now. Also if you dont wanna go with an intake you can get a drop in K&n also helps a little with gas mileage.
Old Jul 10, 2011 | 10:20 PM
earlyre's Avatar
earlyre
Originally Posted by darthroush
You'll have to remove the factory air box, yes. The plastic splash guard and tire will probably have to come off, just for installation. That shield goes back on. How long will it take? Depends on your skill. Just take your time and do it right.
i'll 99% agree with ya darth, but you don't HAVE to lose the factory box.
Mine has a CAI, with the tube running through the (Gutted/sliced/diced) factory box. the net effect is when you open the hood it pretty much looks stock. I can try and put up some photos if anyone is interested..
I didn't do the install, so i don't know why it was done this way, (used to be my Brother's Car, he did the install)
my best guess is to try and "hide" the intake from the annual enviro inspection in his part of Texas.
Old Jul 10, 2011 | 11:50 PM
darthroush's Avatar
darthroush
Section Moderator
I guess you could do it like that. I wouldn't want that huge box with all of that "dead space" sitting in the middle of my intake, but to each his own.
Old Jul 11, 2011 | 04:22 PM
earlyre's Avatar
earlyre
Like i said, not my choice, might disassemble the whole thing @ sometime, and take the empty box out of there. maybe.
Old Jul 11, 2011 | 05:19 PM
darthroush's Avatar
darthroush
Section Moderator
I know, I meant more about him doing that. Does the tubing go through the box, or does it connect to it on the sides?
Old Jul 11, 2011 | 06:51 PM
Andrew201183's Avatar
Andrew201183
Thanks for the advice guys. It all went smooth, i got it on last tuesday but havent had time to get on.. but a small concern for me is that air silencer box behind the plastic piece in the fender, my new filter is exposed.. the box came off with installing the new one, should there be something i can rig for it to protect it? is it a problem if its exposed without protection? i dont want any troubles with it.. any advice?
thanks guys!
Old Jul 11, 2011 | 10:00 PM
earlyre's Avatar
earlyre
you should be good. if i put my head under the fender, and look up like i'm looking @ the back of the side marker light, or underside of headlamp, the filter is right there. exposed to the world..if i pull the driver's headlight, there she is. and besides, you want it in the airflow.
I'm assuming it is the standard cone type filter? k&N sell what they call "dry chargers" basically a fine mesh stocking that slides over your filter, with a hydrophobic (Water Fearing, as opposed to hydrophyllic, or water loving)coating. Can be helpful if you live in an especially rainy, or dusty environment.
I'm sure other manufacturers make similar devices. K&N Link : http://www.knfilters.com/search/wrap.aspx
darth:
goes through, he cut the box, not the intake tube. Fully gutted whatever structure was in there(the box) to hold the factory filter, & cut Slots, or Drilled holes large enough for the black plastic intake tube to pass snugly through.
If i ever would want to go back to the stock intake, i would need to obtain an airbox. i have all the other parts boxed up around here somewhere...
Old Jul 11, 2011 | 11:37 PM
darthroush's Avatar
darthroush
Section Moderator
I guess as long as the intake tube isn't separated like I was first thinking (CAI to factory box to CAI again), it wouldn't matter. Just a lot of work, lol.
