Solenoid Problem
Old Jul 21, 2011 | 11:46 PM
NeonDan's Avatar
NeonDan
Default Solenoid Problem
Hey everyone,
I have a 2002 Dodge Neon and I was over in New Jersey and it drove fine on the way there. Well on the way back the car started to make a noise after you drove past 30mph. Turns out the mechanic that it was brought to said I would need a new solenoid.
So i purchased this one http://www.amazon.com/ATP-TE-6-Autom...1306207&sr=8-1
turns out the website said it would work on a 2002 neon but the paper in the box said for 98 cars or earlier.
it looked the same so we installed it and then the car will be in drive and wont do anything. it will just go backwards a lil bit or just sit there. and fluid leaked out under the car.
we didnt have the middle bolt the tightest on there and the cable that plugs into this wasnt on too tight but it was staying and we did hook the cable back into the tube above the middle screw.
any ideas on what i can do to resolve this problem?
Neon has 101,145 miles on it.
Old Jul 22, 2011 | 12:29 AM
darthroush's Avatar
darthroush
Section Moderator
No old gasket material got into any of the holes on the transmission, yeah?
Old Jul 22, 2011 | 12:34 AM
NeonDan's Avatar
NeonDan
when we pulled out the old solenoid i was black left from the old solenoid sitting there.
could that be it or did we not have it bolted down tight enough?
Old Jul 22, 2011 | 01:42 AM
darthroush's Avatar
darthroush
Section Moderator
Sorry...what? You left the old gasket there? If that's what you meant, then yes, that's a problem.
Old Jul 22, 2011 | 09:53 AM
NeonDan's Avatar
NeonDan
so if we scrape the old gasket completely off it should work?
Old Jul 22, 2011 | 01:59 PM
darthroush's Avatar
darthroush
Section Moderator
Well, you should never leave the old gasket on anything. I'm not quite sure how you got the old solenoid off without taking some of the old gasket with it. If your "mechanic" did that, I'd take the car far, far away from there.
Old Jul 22, 2011 | 02:14 PM
NeonDan's Avatar
NeonDan
my question is that if i got it completely silver with none of the old gasket left on whatsoever then it will work?
Old Jul 23, 2011 | 06:20 AM
darthroush's Avatar
darthroush
Section Moderator
No, you need to put the new gasket on or it will leak just the same. The surface needs to be carefully scraped (it's aluminum; it'll gouge fairly easily) clean until it is all silver and no gasket material in any of the holes/ports, and then the new gasket put on.
As for "will it work," no one can say yes or no. If that wasn't the problem or it's a DOA part, then probably not. If it really is the problem and it's a good part, then it should.
