Cluster swap
Old 11-30-2012, 09:40 PM
Moparman7284's Avatar
Moparman7284
Moparman7284 is offline
Default Cluster swap
I've got an 02 and I'm not happy with how it looks I'd love to swap it with a newer one from like an 05 I'm curious if it will drop right in with no problem or would I have to move wires around and change connectors
Old 11-30-2012, 11:18 PM
buddhaman's Avatar
buddhaman
buddhaman is offline
Take the old one out, plug the new one in. Swapped the cluster from my 2000 with one from a 2003.
Old 11-30-2012, 11:22 PM
Moparman7284
Would the tach work also j/c cause I'm use to the old school cars
Old 12-01-2012, 12:07 AM
buddhaman's Avatar
buddhaman
Yup, that's the reason I swapped clusters.
Old 12-01-2012, 03:23 PM
fhadso's Avatar
fhadso
fhadso is offline
Yep. Your mileage won't transfer over, though.
Old 12-13-2012, 10:35 PM
Neonewbie's Avatar
Neonewbie
Neonewbie is offline
so if I do this I will finally have a tach?
The only thing I would need to do is write down the exact miles pre swap correct?
Old 12-14-2012, 12:17 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Yes. I have heard a dealership (or a shop with the DRBIII) will correct the mileage as long as it needs to go up. They obviously cannot legally rollback the mileage.
Old 12-14-2012, 01:56 PM
TejasMtnBiker's Avatar
TejasMtnBiker
TejasMtnBiker is offline
there's a crack on YouTube for changing this models cluster mileage, I saw a while back. Could never figure it out on my original so I never swapped them out. Has anyone changed the back lighting any here?
Old 12-15-2012, 02:53 AM
fhadso's Avatar
fhadso
fhadso is offline
Yes, I have. It's really easy. Although some model years use hard wired sockets. You can change the sockets all you want, but you can't take out the b ulbs as easily. I just order some aftermarket twist sockets and installed 20SMD LEDs.
Old 12-15-2012, 03:50 AM
darthroush's Avatar
darthroush
Section Moderator
You can change it to blue or green just by changing the bulbs. Any other color, and you'll be sanding the cluster.
Quick Reply: Cluster swap
