Accomadating srt-4 tires
Old Feb 3, 2006 | 12:46 AM
fastback79's Avatar
fastback79
Default Accomadating srt-4 tires
I'm sold on getting srt-4 17in rims for my 04sxt. Is it true that to fit the srt-4 tire sizes, all I have to do is put in the srt-4 springs and struts? Or do I need to make more modifications? I don't like the skinny tires on the srt-4 rims. I want some meat on them without rubbing the struts.
Old Feb 3, 2006 | 01:37 AM
neon2_0t's Avatar
neon2_0t
Default RE: Accomadating srt-4 tires
No modification is needed at all to install them.
Old Feb 3, 2006 | 01:47 AM
Freerider's Avatar
Freerider
why would you need to change springs to put on SRT-4 wheels? They will go on with little trouble
Old Feb 3, 2006 | 02:12 AM
fastback79's Avatar
fastback79
yes, the wheels will go on, but the srt-4 spec tires will rub against the stock struts.
Old Feb 3, 2006 | 02:48 AM
LowSlowNeon's Avatar
LowSlowNeon
You're gonna want different tires. Unless you want to swap suspenion. Well depending on what model neon you have..it might be slightly different. Just using my stock tires for example....185/60/15. The SRT4 stock tires are 205/50/17s. If you don't change the tires and just try to bolt them up it would be 1.4 inches taller then your stock tires. That will almost guarantee that you will have fitment issues, plus its going to throw your speed off and mileage. You could also just get different tires for your car. That would be easier. Hopefully that helps a bit.....
Old Feb 3, 2006 | 02:56 AM
fastback79's Avatar
fastback79
I will probably change the suspension, because I like the look the the srt4s thicker tires. From what I've researched, I just have to change the struts to srt4 struts.
Old Feb 3, 2006 | 03:00 AM
LowSlowNeon
I think you'll need the springs for it as well. I think their springs are different then stock neon springs. Tires would be the easiest......and probably cheaper then replacing the struts/springs.
Old Feb 3, 2006 | 01:44 PM
whyte69's Avatar
whyte69
a lot of the SRT-4 guys complain about traction issues with the stock tires. One of the first things they do is go out and buy a wider tire, which will give them some better traction. Instead of getting a tire/rim combo that suits the SRT-4, why not get one that is made for the Neon? Granted, they are near the same, but you can already see that there are going to be some issues. Go to www.tirerack.com to pick out some nice rims/tires for your car. You can always go into a brick and mortar shop to talk to a real person about what's going to fit and what isn't. Changing your tire size would require that you take your car in anyways to fix the car's computer to read the proper mileage anyways, so they'll probably tell you if your new tires will fit your car or not. The tire rack will give you a pretty good idea of where to start, from there, minor changes like spacers is all you need to worry about.
tooslow's Avatar
tooslow
the wheels will fit with your stock suspension
some useless info
if you only put srt springs on your car without srt strut it will lower your car about an inch- cheopo lowering springs
and srt struts will raise your car since the srt whieght is more and the perch is 3/4 higher
Old Feb 3, 2006 | 02:16 PM
LowSlowNeon
ORIGINAL: tooslow
some useless info
I think everyone knows the wheels fit. The tires are what do not...not to mention your speedo would be off.
