Downstream 02 sensor simulator Questions???????
Old May 16, 2006 | 03:42 AM
NHARINTON's Avatar
NHARINTON
Default Downstream 02 sensor simulator Questions???????
Any one know of this doing anything bad to a 03 se or anyother car for that matter???
i am thinking abot getting one cause i have the obx test pipe and with no cat, and it set of the CEL (p0420)
just trying to get opinions!!!
https://www.casperselectronics.com/M...Category_Code=
thanks
Old May 16, 2006 | 12:04 PM
ewetho's Avatar
ewetho
Default RE: Downstream 02 sensor simulator Questions???????
You already did the bad thing by removing your pollution equipment, that should just turn off you CEL if built right.
Old May 16, 2006 | 03:02 PM
NHARINTON's Avatar
NHARINTON
Besides the pollution aspect what is bad about removing the cat??
Old May 16, 2006 | 03:58 PM
tooslow's Avatar
tooslow
ok not sure if that works but there is much cheaper way too turn of that code all you need is 2 18mm sparkplug defoulers and a drill
ok here is how you do it
1. remove lower o2 the screw in one defouler were it was
2. Drill out the second one so that the o/2 can screw into it then just screw the whole thing into the other none fouler
I have been running with this for almost a year and no code it will cost you about $3-6
Old May 16, 2006 | 05:35 PM
NHARINTON's Avatar
NHARINTON
Sounds great but what is a defouler and wear can i get them???
got any pic's??
the sensor thing work by sending the same electro signal to the computer as the 02 would send.
Old May 16, 2006 | 06:53 PM
tooslow's Avatar
tooslow
yeah I know but alot of pll say they dont work for the neon but one of my buddies has one for a honda also from the same company casper sim and it worked for him
defouler can bebought at any parts store I bought mine from Autozone they already come two in a packet just ask at the counter
Old May 16, 2006 | 11:54 PM
NHARINTON's Avatar
NHARINTON
so you are saying that the 02 sensor go's inside the defouler which is screwed into the downpipe were the o0 sensor was???
im kind of confused!!! [][][&:][&:]a pic would be awsome!!!!!!!!!!!!!!!!!!!!!
Old May 18, 2006 | 04:03 PM
tooslow's Avatar
tooslow
I pm ed you got a pic but it is way too big. I don't have any program too make it smaller
Old May 18, 2006 | 09:40 PM
spikeymikey87's Avatar
spikeymikey87
can u pm it to me too because im going to have the same problem if modernperformance.com ever sends me mine
Old May 19, 2006 | 12:29 PM
NHARINTON's Avatar
NHARINTON
hERE FOR EVERYONE THAT NEED THIS HERE IS THE WRITE UP, WIT PICTURES ON HOW TO DO IT!!
http://forum.2gn.org/viewtopic.php?t=1025
iT TOOK ME MABY 5 MIN INCLUDING DRILLING TIME AND IT HAS SHUT OFF THE CODE FOR NOW!!!
