Improve Car Acceleration When AC is On
Old Aug 11, 2006 | 06:15 PM
redskinz56's Avatar
redskinz56
Default Improve Car Acceleration When AC is On
Im looking to improve the acceleration on my car in general but especially when the ac is on I've noticed my car drives as if it has 10 obese people in the car. My gas goes down much more quickly too when the ac is on. I know its normal for the gas to go down faster when AC is on but is there anyway to improve this?
Thanks!
Mike
Old Aug 11, 2006 | 09:16 PM
03neonRT's Avatar
03neonRT
Default RE: Improve Car Acceleration When AC is On
The only way to do this is to replace your UDP with a lightweight onem, and even then it wont give you that much power back...the stock Neon A/C is fairly powerful, and thus takes away a lot of power from the engine when its on...but you cant have it both way in a Neon. Its either comfort or performance.
Old Aug 12, 2006 | 06:15 PM
hokiefan104's Avatar
hokiefan104
so is an underdrive pully worth the cost?
Old Aug 12, 2006 | 06:31 PM
lblackneon's Avatar
lblackneon
I agree with 03neonRT. I have a AFX underdrive pully and it improved the power with the AC on. That was the most noticeable thing. Other than that, it doesn't really improve the performance with the AC off. It improves it a bit but it's barely noticeable.
Old Aug 12, 2006 | 07:03 PM
CA180's Avatar
CA180
well, one thing i was tought in any performance modification was that it just like the newtons third law of motion...(had to say it to sound smart!lol) for every action there is an equal or opposite reaction... what i mean is that, you may gain in one area, but in turn you will lose in another area. Thats why you really have to think out mods before you do them. I see it like this, you install an UDP and you gain because of the less force used to turn the other pulleys... but at the same time, the a'/c sompressor being turned at a slower rate reduces it functional performance... the underdriven alternator in turn reduces the output of the alt which can effect charging sytems, battery life, and maybe even effect the ignition system, which could lead to a loss of performance. Now, i'm sure it may not change these things in a drastic way, but you still gotta think "is this worth it?"
Old Sep 6, 2006 | 07:48 PM
redskinz56's Avatar
redskinz56
what is a UDP?
Old Sep 6, 2006 | 07:50 PM
03neonRT's Avatar
03neonRT
UDP = Underdrive pulley a.k.a crankshaft pulley
Old Sep 6, 2006 | 08:10 PM
Freerider's Avatar
Freerider
Dodge was also being a panzy when they made it so you need the specific tool to get the UDP OFF to begin with. I have been holding off on an UDP for the very reason that it can both give and TAKE performance.
My way around it....
dont use the AC! i just roll down the windows and cruise.
Old Sep 7, 2006 | 06:26 AM
2003SXTneon's Avatar
2003SXTneon
I agree with freerider, windows down hearing my exhaust/CAI sucking air.....NICE
Old Sep 7, 2006 | 04:42 PM
03neonRT's Avatar
03neonRT
^^I agree, windows down is the way to go...but its not just Dodge, you need a pulley puller of some kind to get the crankshaft pulley off of any type of car.
