HELP!! Shopping list for motor rebuild and turbo
Old Sep 24, 2006 | 11:35 PM
spikeymikey87's Avatar
spikeymikey87
Default HELP!! Shopping list for motor rebuild and turbo
ok guys im gonna build up a motor and turbo it and drop it in my car and ive made a shopping list. can you please let me know what i have forgotten and what are some good brands, prices, and places to buy them. thanks a lot this is what i have so far
PART -------------------------------- BRAND
turbo, manifold, and wastegate --srt4 stock
intercooler ------------------------------- Srt-4 stock
injectors (4)
fuel pump------------------------------- walboro 255 lph
oil pump------------------------- Melling M190
pistons (4)---------------------------------JE
rods (4)---------------------------------Eagle
piston rings (4)-----------------JE
extra head gasket-----------------Mopar
oil pan gasket----------------Mopar
exhaust gaskets srt-4 and 2.0-------Mopar
turbo manifold adapter--------------Maddog
fuel management unit
hot and cold side intercooler piping
blow off valve
boost gauge
oil pressure gauge
fuel pressure gauge
downpipe
doner car---------------------------------- 2003+ dodge neon 5-speed
alternator voltage regulator-------------1986 dodge omni 2.2L chrystler P/N 4379100 SAE P/N VR-125
gauge pods
megasquirt ecu
wiring harness
coolant temp sensor
iat sensor
stage 4 clutch----------------------------Clutchmasters
vacuum and boost lines
injector plugs (4)
timing belt --------------------------------Mopar
blow off valve block of plate
rod bearings (4)
main bearings
thermostat
sorry the format of my list kinda sux
Old Sep 24, 2006 | 11:49 PM
spudsterier's Avatar
spudsterier
Default RE: HELP!! Shopping list for motor rebuild and turbo
why 2 main bearings???....get a whole main bearing set....comes with 5 sets
rear main seal
get a headgasket set.....it comes with just about all gaskets....and get an intake gasket
srt4 02 housing
boost controler....just a good idea
get a new timing belt tensioner pulley
and get a new throw out bearing
how come a bov block off plate???...why not just go with a mopar BOV
ive heard bad things about the melling oil pump
just remember if you rebuild the motor.....its a good idea to take the block to a machine shop and have it honed and the head resurfaced
Old Sep 25, 2006 | 01:01 AM
spikeymikey87
i already got a place to bore and hone it not sure why i put down 2 main bearings i should fix that
and for the bov i wanna get a greddy type r
Old Sep 25, 2006 | 03:00 AM
03neonRT's Avatar
03neonRT
Everything on your list along with what spudsterier said seems to be a pretty complete list, theres always little things you'll need, and i'm sure theres something i missed besides the need for a wideband A/F gauge ($280)...
But let me ask you this, what is the goal of your project?
Oh and here are some prices for you, i can go through it in more detail when its not 12:30 AM...i would also highly suggest MP for most of these parts, and your local auto parts store for your OEM needs.
turbo, manifold, and wastegate -- srt-4 $200.00
intercooler ------------------------------- srt-4 stock $100.00
injectors (4)--------------------- stage 0's-stage 1's $100.00
fuel pump------------------------------- $100.00
*oil pump------------------------- melling m190
*pistons (4)---------------------------------JE
*rods (4)---------------------------------Eagle
*piston rings (4 SETS)-----------------JE
*oil pan gasket----------------Mopar
turbo manifold adapter--------------Maddog $216.00 w/gaskets
fuel management unit $200.00
hot and cold side intercooler piping $200.00+
blow off valve $200.00
boost gauge $30.00
oil pressure gauge $50.00
fuel pressure gauge $50.00
downpipe - srt-4 or agp? $50.00-$150.00
gauge pods $60.00
megasquirt ecu $400.00
wiring harness
coolant temp sensor
iat sensor
stage 4 clutch----------------------------Clutchmasters $600.00
injector plugs (4)
blow off valve block of plate $20.00
*rod bearings (4)
*main bearings
thermostat
* = MP bottom end kit - $1,200
Old Sep 25, 2006 | 12:24 PM
spikeymikey87
im looking to have 300+ whp and not blow myself up lol
Old Sep 25, 2006 | 12:54 PM
03neonRT's Avatar
03neonRT
ORIGINAL: spikeymikey87
If thats the case why are you using the stock SRT-4 turbo and intercooler? The TD04 will max out at 330whp or so, and thats with other mods and on a 2.4 engine. Not to mention the fact that your cutting down the turbo's life.
Old Sep 25, 2006 | 12:55 PM
spudsterier
if you want that much power then why dont you spend about the same amount of money and throw in a srt engine and then get either a 50 trim turbo or a stage 3 kit????
Old Sep 25, 2006 | 04:16 PM
tooslow's Avatar
tooslow
why you don't need it
and this
fuel management unit $200.00 if you go megasquirt don't need it too
Old Sep 25, 2006 | 10:09 PM
spikeymikey87
ok cool i wasnt really too sure about that and for the turbos i wanted to start out small and then go big. 300+ is my ultimate goal and as for just dropping in an srt motor, that would be perfect if i can get one thatt i know wasn't beaten on which i know is never going to happen. everyone beats on an srt motor, and if i rebuild my own 2.0 i know all of the parts and brand new and good
Old Sep 25, 2006 | 11:32 PM
nicks2kes's Avatar
nicks2kes
doesnt matter about the engine being beat on. if u get one with low miles than ur allset, i bet an srt motor would have less wear and tear on the internals than ur engine
