A little LED work...whaddya think?
Old Oct 3, 2006 | 10:35 AM
04r/t_11's Avatar
04r/t_11
Default A little LED work...whaddya think?
Started my interior LED work, the cluster, HVAC, defrost switch, and some in the little cubby. What do yall think?
[IMG]local://upfiles/23425/1327AE41D9B34C919514AAE1731D1A3B.jpg[/IMG]
[IMG]local://upfiles/23425/D2B2104292634F48B677915BAE1F903F.jpg[/IMG]
Old Oct 3, 2006 | 12:43 PM
FyreDaug's Avatar
FyreDaug
Default RE: A little LED work...whaddya think?
thats just LED? Looks pretty good man, are there any bright/dull spots?
Old Oct 3, 2006 | 08:59 PM
spikeymikey87's Avatar
spikeymikey87
looks good did you get the hvac from gmr?
Old Oct 3, 2006 | 09:24 PM
JarheadX's Avatar
JarheadX
I love that, i'd like to do that I love blue gauges.
Old Oct 3, 2006 | 09:59 PM
timplett's Avatar
timplett
What type bulb and how many did it take for the cluster and the HVAC?
Old Oct 3, 2006 | 10:04 PM
fraggle_a's Avatar
fraggle_a
Thats nice.
You just swapped out the stock with the blues?.
(Ya can get 12v HO LEDs at radioshack)
Im planning the same kinda thing, but with purple, or aqua maybe.
It will eventualy match the external lighting... when I settle on a color
(Not white, cause the cars white, Not blue, red, green or yellow for obviouse reasons)
Old Oct 3, 2006 | 10:35 PM
04r/t_11's Avatar
04r/t_11
I used blue inverted cone #194 LEDs from ebay for the cluster, they just swap with the stock bulbs on 00-04. You can only do blue or white because of the green film Dodge puts on them, there is a way to do any color, but it's far more work. The HVAC is stock, but I re-wired the bulbs with 5mm blue LEDs and resistors, again ebay. same with the defrost switch. And the cubby I just put two clusters of 3 LEDs and wired them to the defrost switch so they work with the lights/dimmer. I highly recomend using heat shrink tubing for any wiring work, it was my first time using it and it had better results than tape and connectors. There is a better how to on annother forum, I believe it's an affitiliate of this one, for the SRTs.
srtforum.com
I plan on doing blue under the seats and dash and door pockets as well, but no time right now. Thanks for the compliments, I was very happy with the results.
Old Oct 5, 2006 | 12:18 AM
sxt_seven's Avatar
sxt_seven
those are sick!!!!!!!!!!!!!!!! looks better then stock
ORIGINAL: 04r/t_11
