Spark Plugs/Wires
Old Dec 6, 2006 | 03:23 PM
Kaishepard0723's Avatar
Kaishepard0723
Default RE: Spark Plugs/Wires
When you replace your plugs are you suppose to replace your wires and how often should you replace you plugs and wires??????????
Old Dec 6, 2006 | 03:51 PM
spikeymikey87's Avatar
spikeymikey87
no wires change at like i think 15000 aboutish and plugs you can change like every 5000 if you want
Old Dec 6, 2006 | 04:24 PM
03neonRT's Avatar
03neonRT
ORIGINAL: spikeymikey87
DCx recommends changing spark plugs every 30,000 miles and replacing the plug wires when they show signs of wear or corrosion. I change my plugs every 20,000 miles and do the plug wires at the same interval.
Old Dec 6, 2006 | 05:32 PM
Pablodragon's Avatar
Pablodragon
Still wondering if the code I got 'Cylinder #1 misfire' means a plug or wire...
will probably try the $1.79 each plugs first.....
and still think the prices we are discussing about plug wires is an aweful lot.....
come on, $30 to $45 for (4)- 5 or 6 inch wires?
Old Dec 6, 2006 | 05:56 PM
fullbuilt's Avatar
fullbuilt
just rememer to change all four at once.
Old Dec 6, 2006 | 06:39 PM
Pablodragon
ok, thanx
Old Dec 7, 2006 | 11:28 AM
Kaishepard0723
Ok so I think its time for me to change my plugs considering I have 54,000 on my car and I have not yet done it, I think I wil do that this weekend, What plugs would be good for me to get??
Old Dec 8, 2006 | 12:33 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
i change my wires every 25k (rec. at 30k). but the plugs themselves i try to remember to check each oil change for buildup. they are cheap enough to replace at least semi-annually. just remember to plug the wire back in the whole way so you arent running on 3cyls like i was for about a week. and i wondered why my mileage was sucking a$$
Old Dec 8, 2006 | 12:40 AM
Freerider's Avatar
Freerider
ORIGINAL: Kaishepard0723
the copper plugs like the ones in your car now work just as well as the majority of plugs you could buy. They are relatively cheap and do a good job. If your looking for something a tid bit more pricey, look at iridium plugs
Old Dec 8, 2006 | 01:15 AM
03neonRT's Avatar
03neonRT
ORIGINAL: Freerider
Buy some Denso plugs if you feel like spending $60 every time...
