will thies tires fit??
Old Nov 28, 2006 | 10:12 PM
NHARINTON's Avatar
NHARINTON
Default will thies tires fit??
205/75 zr 17 on a 2003 neon Se with stock suspension?
[IMG]local://upfiles/24713/B441F4D02C384C70AE455B6D4DC94108.jpg[/IMG]
Old Nov 28, 2006 | 10:17 PM
fullbuilt's Avatar
fullbuilt
Default RE: will thies tires fit??
what was the original size.
Old Nov 28, 2006 | 10:24 PM
fullbuilt's Avatar
fullbuilt
you should have trouble turning and youll be of by 15mph at 60.
Old Nov 28, 2006 | 10:27 PM
NHARINTON's Avatar
NHARINTON
original was 175/70 r14
And trouble turning... i will lose turning radius?
Old Nov 28, 2006 | 10:56 PM
spikeymikey87's Avatar
spikeymikey87
rims will fit tires WILL NOT if they are stock srt. just get some wheel spacers. if you wanna get some hure 30mm ones i have some that im tryin to sell
Old Nov 28, 2006 | 11:35 PM
fullbuilt's Avatar
fullbuilt
those tires are 50s and they will fit and youll only be off by3.5mph at 65
Old Nov 28, 2006 | 11:50 PM
spikeymikey87
i believe that the stock srt tures will not fit because they are too wide.
Old Nov 28, 2006 | 11:53 PM
fullbuilt's Avatar
fullbuilt
you might still get some rub but its not worth putting on spacers
Old Nov 29, 2006 | 12:55 AM
03neonRT's Avatar
03neonRT
Its not that they are too wide, its that the sidewall is slightly too tall...on a 50 series you'll be pushing it, you'll probably have some slight rubbing on the spring perch...
Old Nov 29, 2006 | 01:00 AM
NHARINTON's Avatar
NHARINTON
well the girl wants 200 bucks for all 4. Why would getting spacers be a bad idea..... I also plan on ordering a wide body kit in the next few weeks so a bit wider is a good thing??? So i think a little rub when full turning is ok till i can get the tokio hp's...... or will it rub enough to blow the tires?
