Found the Real Problem Need some help...
Old Dec 19, 2006 | 07:08 PM
Izero's Avatar
Izero
Default RE: Help.... I've Got NO LOW BEAMS!
relay.....? wheres that? is that inside the multiswitch...
Old Dec 19, 2006 | 07:15 PM
Izero's Avatar
Izero
PMed you tooslow
Old Dec 19, 2006 | 09:37 PM
tooslow's Avatar
tooslow
ORIGINAL: flamingpinhead
yup, multiswitch or relay
lol, for 2000 bucks, if it was just the headlights not working i would wire them bitches on a friggin toggle switch!
no they wanted too replace the whole inside wiring harness since the plugs got burnt
Old Dec 19, 2006 | 11:23 PM
Izero's Avatar
Izero
ohhh i see... ha! i hate the dealer... honestly unless my car is under warranty i wont bring it there... they charge too much for everything
Old Dec 31, 2006 | 07:30 PM
Izero's Avatar
Izero
ok so i tried switching the multi switch but now i found that the little wiring harness back there is melted so im guessing that is what the problem is...... does anyone know what the part # is, or how much the dealer sells them for? i've been trying to look around at salvage yards but no luck so far...
Old Dec 31, 2006 | 09:45 PM
snare_samn's Avatar
snare_samn
That's strange cause I've got the opposite problem. I have no high beams at all, or rather, none that will STAYon. When I pull the switch towards myself to turn on the high beams, they come on for a second but then go back off when I let the switch go back into place. The only way I have high beams is if I hold the high beam switch right next to the steering wheel.
Old Jan 1, 2007 | 12:47 AM
hokiefan104's Avatar
hokiefan104
have you tried all new bulbs, you can get a cheap set at wal-mart for like $10.
Old Jan 1, 2007 | 01:00 AM
ewetho's Avatar
ewetho
Not sure about MOPAR but at ford we do sell almost all the connectors (Yeah you have to order some but hey) and the you just rewire with Quality wire.
Old Jan 1, 2007 | 03:48 AM
Izero's Avatar
Izero
so does anyone know what the part is called, how much it is(usually) [both at the dealer and at the salvage yard]? b/c i neeeeeeed my carfixed ASAP
Old Jan 1, 2007 | 04:48 PM
ewetho's Avatar
ewetho
I would ask for the connector pigtail that goes to the appropriate nearest connector. I assume from above that it is the multifunction switch. Anyhow after that you just need to splice in wire (soldering best followed by but connectors with adhesive lined shrink wrap. Then tape up the harness when done. Should be golden after that. Get the best wire you can (gas, oil, water, etc. etc. resistant).
Best of luck.
Those parts are not listed generaly to the public or in a normal parts manual but should be readily available at the dealership.
