Found the Real Problem Need some help...
Old Apr 11, 2008 | 12:39 PM
  #31
Izero's Avatar
Izero
Default RE: Found the Real Problem Need some help...
i dont think those will help b/c the higher wattage bulbs will still draw that current through the multifunction switch thus causing it to heat up and melt.... :-\ to run higher wattage bulbs you need an HID system..... oh and HOLY DEAD POST BATMAN!
Old Apr 12, 2008 | 11:40 PM
  #32
jay2679's Avatar
jay2679
no im not running high voltage bulbs. This has nothing to do with the head lamps. Its the Fog/Switch. I picked up a new multifunction switch and the mfg made changes to the module for it. I can post pics once i get the chance.
Does anyone know where the tie off plug is to replace the connectors for the multifunction switch ?? or am i going to have to replace the "entire" harness all the way to the firewall. Boy what a mess.
Old Mar 5, 2010 | 03:38 PM
  #33
KrazyPyro77's Avatar
KrazyPyro77
bump for wiring assembly
Old Mar 7, 2010 | 11:42 AM
  #34
Twkdout066's Avatar
Twkdout066
If you want higher power headlights you can do it but it takes running some new wire and buying some relays. I have the information somewhere when I rewired my cuda. Now the headlights in it don't dim with the engine RPM.
