r/t vs. (regular) neon
Old Feb 4, 2007 | 03:29 PM
black01rt's Avatar
black01rt
Default r/t vs. (regular) neon
what are some advantages that the neon r/t has over the (regular) neon...
Old Feb 4, 2007 | 05:36 PM
Freerider's Avatar
Freerider
Default RE: r/t vs. (regular) neon
Top Speed.....
The R/T comes with a few better things and has only a rev limiter I believe.
This vs a regular neon.... = R/T > SXT/SE
Old Feb 4, 2007 | 10:07 PM
fullbuilt's Avatar
fullbuilt
better cam, better intakemanafold, rear discs
Old Feb 5, 2007 | 01:17 AM
crracerus's Avatar
crracerus
im r/t all the way! the biggest difference i can tell from driving them is the handling and braking. there is a pretty big power difference too
Old Feb 5, 2007 | 01:25 AM
lblackneon's Avatar
lblackneon
The RT has a better cam, intake manifold, LARGER EXHAUST PORTS, 4 disc brakes, and a higher performance computer. That's all I can think of.
Old Feb 5, 2007 | 04:07 AM
03neonRT's Avatar
03neonRT
Performance wise:
[ol][*]Magnum Cam (equivalent to a Crane 12) w/ stronger valve springs.[*]Aluminum Dual-Runner Intake Manifold with functioning butterfly actuators.[*]2.25" Dual Outlet Exhaust[*]Magnum Exhaust Manifold (Same as the aftermarket Borla header).[*]Magnum Head (larger intake/exhaust ports, much better flowing).[*]No top speed limiter...same rev limiter though.[*]Four-wheel disc brakes with ABS (rear discs are the same as on SRT-4's).[*]Stiffer spring rates and front/rear sway bars.[*]"Firm Feel" Power Steering.[*]Different PCM programming...along with different fuel maps and better spark timing.[*]9.8:1 Compression Ratio.[*]3.94 Final Drive Transmission (thanks tooslow ).[*]I think thats everything... [/ol]Body Difference:
[ol][*]Side skirts[*]Rear Bumper w/ Dual Outlet Exhaust Cutouts.[*]Different front seats[*]Leather steering wheel/shift ****/shift boot/optional leather seats.[*]16" Aluminum Alloy Wheels [/ol]
Old Feb 5, 2007 | 02:21 PM
tooslow's Avatar
tooslow
another one
12. shorter gear ratio
Old Feb 5, 2007 | 05:01 PM
03neonRT's Avatar
03neonRT
ORIGINAL: tooslow
another one
Damn how could I have forgot about that! Thats like my favorite part about the R/T...
