how too trick your computer if no cat
Old 03-06-2007 | 12:22 AM
tooslow's Avatar
tooslow
Default RE: how too trick your computer if no cat
ORIGINAL: NHARINTON
I did this for about 4 mths and it becomes a pain in the but cause the defoulers always come loose. For about $20 their is a little divice that goes in the wireing and does the trick. They are all over on ebay and it worked great for me!! Of course the best thing to do is what i ended up doing and paying for a obd 2 hi flow cat. then you have no probs and the engine can correctly adjust the fuel, spark and let you know if the cat is bad!!!
that is funny mine has never came loose I did not have problem with it for more than a year.
Old 03-06-2007 | 12:25 AM
NHARINTON's Avatar
NHARINTON
thats weird... i cranked that SOB so tight after it came loose and still within 2 weeks it was loose. Maby i just had cheap de-foulers??? Not sure that was just my 2cents!!
Old 03-06-2007 | 12:36 AM
tooslow's Avatar
tooslow
I used a gutted cat maybe it has some thing too do with the obx down pipe
Old 03-06-2007 | 09:09 PM
03neonRT's Avatar
03neonRT
I'll add a link to this threadin the 2nd Gen FAQ so everyone will be able to find it...
Old 03-06-2007 | 10:40 PM
spikeymikey87's Avatar
spikeymikey87
i had the nonfouler trick on my obx header and downpipe for a while with noproblems whatsoever. maybe you overtorqued the bolt and stripped them
Old 01-18-2009 | 11:37 AM
hertzog1284's Avatar
hertzog1284
Originally Posted by tooslow
ok here is what you need
1. 18mm Spark plug Non-Fouler (come in 2 per pack) you can get it in the help section of most parts stores
2. drill and 7/16 drill bit
3. 7/8th wrench or adjustable wrench
4. vise or something too hold it while you drill it
ok here is how the defouler looks mine is dirty since I just pulled it out of the car too take some pics
if you look at the defouler it will only have small hole on the one side like this
all you do isdrill it soand it shouldlook like this
you only need too drill one just make sure you make sure too get all the metal shavings out of the defouler before you install it.
Screw the drilled defouler into the non drilled one then screw that into the bung on your down pipe/cat
here is how is how it should look when your done
Where do you drill these holes? And do you have to use both non-foulers???
Old 01-21-2009 | 02:24 PM
tooslow's Avatar
tooslow
I wil have too take new pics the weekend I should have some non foulers at mothers house unless she chucked them.
Old 01-30-2009 | 03:20 AM
spec_ops57's Avatar
spec_ops57
Would Locktite thread locker work for something like this, or is that a bad idea?
Old 05-04-2012 | 11:56 PM
xarkhun's Avatar
xarkhun
i just installed an obx header and down pipe on my 03 sxt and got the p0420 code. this was just the thread i was looking for thanx
Quick Reply: how too trick your computer if no cat
