how too trick your computer if no cat
ok here is what you need
1. 18mm Spark plug Non-Fouler (come in 2 per pack) you can get it in the help section of most parts stores
2. drill and 7/16 drill bit
3. 7/8th wrench or adjustable wrench
4. vise or something too hold it while you drill it
ok here is how the defouler looks mine is dirty since I just pulled it out of the car too take some pics
if you look at the defouler it will only have small hole on the one side like this
all you do isdrill it soand it shouldlook like this
you only need too drill one just make sure you make sure too get all the metal shavings out of the defouler before you install it.
Screw the drilled defouler into the non drilled one then screw that into the bung on your down pipe/cat
here is how is how it should look when your done
RE: how too trick your computer if no cat
o i see. because i have been postin everywhere trying to get several opinions as to what the heck is wrong with my car. this is what i have. OBX header, hi flow cat, Magnaflow cat back dual exhaust. I still get that "catalyst low efficiency" code and would like to see what everyone thinks before i go out and spend money on a new cat and or sensor. thanks a lot, i love this forum lol
Trending Topics
I did this for about 4 mths and it becomes a pain in the but cause the defoulers always come loose. For about $20 their is a little divice that goes in the wireing and does the trick. They are all over on ebay and it worked great for me!! Of course the best thing to do is what i ended up doing and paying for a obd 2 hi flow cat. then you have no probs and the engine can correctly adjust the fuel, spark and let you know if the cat is bad!!!
