View Poll Results: What's in your engine?
Mobil 1
28.65%
Royal Purple
6.18%
Amsoil
5.62%
Valvoline Full Synthetic
7.30%
Pennzoil Synthetic
5.62%
Castrol Synthetic
6.74%
Quaker State
6.18%
Havoline Synthetic
0.56%
Whatever the shop sticks in
0.56%
Synthetic Blend (specify in a post)
3.37%
Rotella
6.74%
Conventional (dino) oil (specify in a post)
22.47%
Voters: 178. You may not vote on this poll
Motor Oil
Old May 6, 2013 | 01:02 PM
  #131
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
The Restore is snake oil.
Just sayin'.
Old May 6, 2013 | 01:37 PM
  #132
Jigabop's Avatar
Jigabop
My cummins runs AMSOIL 15w-40 Heavy duty diesel and marine oil (synthetic)
6-speed trans runs AMSOIL synchromesh MTF
xfer case runs AMSOIL ATF
PS runs valvoline PS fluid (no stop leak in the fluid)
the rest runs plain ol oil (whatever was run in it last)
Old May 6, 2013 | 06:31 PM
  #133
dodge dude94
You run motor oil in the front and rear ends?
Old May 29, 2013 | 08:07 AM
  #134
abdodge1500's Avatar
abdodge1500
Valvoline Max life 10w30 synthetic, might switch next time I need to change it, but I've had no problems with it so far
Old Jun 1, 2013 | 04:26 PM
  #135
Paul DeHayes's Avatar
Paul DeHayes
I have a semi-related question in concerns with oil change intervals. On a high-mileage engine (think 219K) with minimal problems, what kind of interval could I expect to get out of a quality synthetic like Quaker State Ultimate Durability? I know you guys say these trucks tend to run better on dino, but since I first bought the truck, it has seen nothing but synthetics (the dealer using Kendall GT-1 I believe, back when it had 199K). I'm probably wasting money with my current 3K interval, but I figured I'd ask fellow owners their thoughts. Thanks guys
Old Jun 1, 2013 | 06:42 PM
  #136
Deadsquiggles's Avatar
Deadsquiggles
I run Mobil 1 Extended Performance 5W-30 with a Mobil 1 filter. If I thought the quality was worth it, I might spend more and run Amsoil or Royal Purple, but I don't see three difference being worth it. And I usually change my oil every 5k miles.
Old Jun 1, 2013 | 10:59 PM
  #137
Paul DeHayes
M1 EP is good oil for sure (I've had great luck with it in the Ram when I used to run it). Not too keen on the price of RP though, considering the additive packs in the major brands are typically sufficient enough for proper wear prevention. I've been sticking with the Mopar filters, pretty good so far, but if I did decide to switch I'd probably go with a Purolator PureOne, which is what I ran in my Grand Prix when I had it. 5K OCI sounds reasonable definitely......
Old Jun 1, 2013 | 11:03 PM
  #138
Deadsquiggles
Yeah, I actually started using Mobil 1 because it just happened to be on sale that day, but about a month after using it, I noticed that my mpg was about 1.5 mpg higher than when i had last changed it so I stuck with Mobil 1 since then.
Old Jul 15, 2013 | 02:43 AM
  #139
99IB4X4's Avatar
99IB4X4
Rotella 15w-40 diesel mix. Has a high ZDPP content that helps clean engine soot. That make it a diesel oil because it destroys gas catalytic converters. I have none, so I no care
Old Aug 6, 2013 | 07:31 PM
  #140
DuckandDodge's Avatar
DuckandDodge
Unrelated to the Ram forum, but I run Valvoline Synthetic Blend 5w20 in my avenger at 48k miles and she loves it.
Btw if anyone has any questions about Valvoline's oils, I'm a Certified Technician for Valvoline.
Oh, and those who are saying Mobil 1 is the better oil... we just bought out every corporate owned Mobil 1 in Florida last December. We have been around over 140 years. We must be doing something right...
