View Poll Results: What's in your engine?
Mobil 1
28.81%
Royal Purple
6.21%
Amsoil
5.65%
Valvoline Full Synthetic
7.34%
Pennzoil Synthetic
5.65%
Castrol Synthetic
6.78%
Quaker State
6.21%
Havoline Synthetic
0.56%
Whatever the shop sticks in
0.56%
Synthetic Blend (specify in a post)
3.39%
Rotella
6.21%
Conventional (dino) oil (specify in a post)
22.60%
Voters: 177. You may not vote on this poll
Motor Oil
Old 11-06-2013, 01:56 PM
utmkiv's Avatar
utmkiv
utmkiv is offline
Mobil 1 10w30 Full Synthetic.
It's what I use in my VWs/Audis as well.
In my opinion it's the best oil on the market. Hands down.
  #152
Old 11-10-2013, 01:39 AM
Ram Driver's Avatar
Ram Driver
Ram Driver is offline
I use Napa 10w30 and Napa gold oil filter.
  #153
Old 11-26-2013, 02:05 AM
army_greywolf's Avatar
army_greywolf
army_greywolf is offline
Mobil 1 Extended Performance Synthetic 10W30 I do notice a slight lifter tick when the motor is hot but only at idle, bump it even to 850 and it stops. Big difference in mileage. I went from 11.7 avg to 12.6, all things considered...that's covering the cost of the oil right there and then some. Now that's a big *** ram with 37s and 7 inches of lift and a 6450lb curb weight with half a tank.
  #154
Old 12-02-2013, 11:52 PM
Dieselweasle's Avatar
Dieselweasle
Dieselweasle is offline
Either Castrol GTX(Conventional) or Quaker State. I put 5W30 Castrol in for the Winter and have a jug of 10W30 Quaker State ready to go for the summer
  #155
Old 05-22-2014, 10:15 PM
Dakota1089's Avatar
Dakota1089
Dakota1089 is offline
What would you guys recommend for my 5.9 with 230k? doesn't seem very leaky so thinking 10w 30 of some sorts?
  #156
Old 05-23-2014, 07:51 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,358 Likes on 3,100 Posts
I burn a fair bit.... so, I use the cheapest 10w40 advance has on the shelf.
  #157
Old 05-23-2014, 08:19 PM
Dakota1089's Avatar
Dakota1089
Thanks, Just finished my oil change and did a minor road test but i went with Mobil 1 regular 10w 30 and the molar filter from wally. And wow just she idle good and just over all it run like a new engine. Now mind you the previous oil was toast and had a crappy filter etc... So it needed it. Will continue to test more Tons of great info in here.
  #158
Old 02-25-2015, 12:04 AM
iagatta's Avatar
iagatta
iagatta is offline
Default 0 mile motor what oil should I run?
Just built and bored a motor has 0 miles high compression cammed motor I wanna run the best oil but will take ur option. Rather spend the extra money on good oil in the long run. Especially when I want to make horsepower.
  #159
Old 02-25-2015, 09:24 AM
HeyYou is offline
Use a good dino oil for break-in. Change it at 500 miles, and run whatever you like.
  #160
Old 03-12-2015, 05:13 PM
BigGreenRam's Avatar
BigGreenRam
BigGreenRam is offline
Castrol high mileage synthetic blend 10w-40.
Quick Reply: Motor Oil
