View Poll Results: How does your Ram breathe?
K&N Intake
24
17.91%
K&N Drop in Filter
22
16.42%
Air Raid
4
2.99%
Volant
8
5.97%
AEM
6
4.48%
AFE
4
2.99%
14X3
33
24.63%
True FLow
0
0%
Fram
5
3.73%
MOPAR Brand
5
3.73%
Other (Please Specify in Post)
23
17.16%
Voters: 134. You may not vote on this poll
Cold Air Intakes
Old Feb 18, 2014 | 09:53 PM
  #91
You can use a shorter filter, or even slightly smaller in diameter...... just alters the way it fits under the hood. (taller would probably run out of clearance.)
You will need a "S" bolt to mount that though. Did it come with one?
Old Feb 18, 2014 | 10:03 PM
  #92
BBartow's Avatar
BBartow
I read the DIY thread for it. The kit comes with the threaded bolt that I'll have to bend and I already picked out the VC breather. I'll probably just go with a Spectre 14x3 filter then since its like half the price of the K&N. I shouldn't have clearance issues with the 14x3 since I have a body lift I assume. Thanks guys.
Old Feb 18, 2014 | 10:12 PM
  #93
stewie01's Avatar
stewie01
I didn't have clearance issues without a body lift but, depending on how your throttle cables are run, you may need a riser.
I couldn't seat my 14x3 flush properly because the cables run directly in the path the 14x3 needs in the front.
Old Aug 22, 2014 | 08:35 PM
  #94
topkin's Avatar
topkin
Well, the air hat from my spectra kit stressed and broke causing leaks. Cheap plastic IMO. Just ordered the Volant kit.
Old Sep 1, 2014 | 09:29 AM
  #95
MedicNathan's Avatar
MedicNathan
So from reading through this, would switching from a K&N Drop in to a 14x3 be worth while?
Already have Hughes Airgap, 52mm TB and doing new exhaust next week, just not sure if I would need the extra flow
Old Sep 1, 2014 | 09:43 AM
  #96
stewie01's Avatar
stewie01
The K&N drop in is probably plenty.
I thinks the 14x3 is more for looks, kinda like a CAI, then anything else...
