View Poll Results: How does your Ram breathe?
K&N Intake
24
17.91%
K&N Drop in Filter
22
16.42%
Air Raid
4
2.99%
Volant
8
5.97%
AEM
6
4.48%
AFE
4
2.99%
14X3
33
24.63%
True FLow
0
0%
Fram
5
3.73%
MOPAR Brand
5
3.73%
Other (Please Specify in Post)
23
17.16%
Voters: 134. You may not vote on this poll
Cold Air Intakes
Old Apr 11, 2012 | 10:43 AM
  #41
A_POLVADO's Avatar
A_POLVADO
I was running a spectra cai but took that junk off and put on a 14x3 with a spectra filter and extreme lid. like it better just for the fact it is not in the way.
Old Jul 5, 2012 | 03:15 PM
  #42
EndIsNear's Avatar
EndIsNear
I have the aFe Cold Air Intake, but got rid of the box, twisted tubing to angle next to coolant reservoir, and replaced oil filter with Amsoil dry flow with pre-screen. Gets cooler air directly through grille.
Old Jul 8, 2012 | 01:39 AM
  #43
S S0DEN's Avatar
S S0DEN
I have the 14x3 too, only thing is you can hear it sucking air at low throttle.
Old Nov 11, 2012 | 10:42 AM
  #44
bunker's Avatar
bunker
Default does it save any gas
the fact that the more air in the motor the better is known. but has anybody seen a MPG diffrence after adding better air flow? and if so how much better and what did you use?
Old Nov 11, 2012 | 10:44 AM
  #45
bunker's Avatar
bunker
Default size
What brand breather did you find? i want to go to the same air cleaner but not sure what size hole or even how it would fit.
Old Nov 20, 2012 | 06:30 PM
  #46
I got this thing. No idea who makes it.
Old Nov 20, 2012 | 06:31 PM
  #47
dlyter09's Avatar
dlyter09
Looks like a AEM intake.. Ive got pretty much the same exact thing
Old Nov 21, 2012 | 08:52 AM
  #48
Thing I dont like is the post that holds the hat on the tb is like 3" longer than it needs to be and the PO just put like 20 washers on it so the nut will tighten it down. You can see it sticking out of the top. Makes it a PIA to get the thing off of there. I could probably just use a long screw or something else.
Old Nov 21, 2012 | 09:20 AM
  #49
stewie01's Avatar
stewie01
Cut it down to the size you need.
Old Nov 21, 2012 | 09:38 AM
  #50
I can't. The whole thing is not threaded and it has a dog leg in it. I "assume" it is the original post from the oem intake. I just got to get around to finding a screw long enough for it.
