Old Mar 4, 2013 | 05:27 PM
  #10351
stewie01's Avatar
stewie01
Installed my new Baja 6" 100watt lights. I have a relay to put them on but it may be awhile before I figure out how to wire it in.
I *THINK* I have an idea...
Old Mar 4, 2013 | 05:44 PM
  #10352
merc225hp's Avatar
merc225hp
Off topic to help
Have a look at the pix see if that helps you. It is a neg switched way to do relays much safer and much ezer that means neg is used at the switch not positive to control the relay on/off. Use one relay per light.
So where it say's new low and new high make these into new light one relay per light, 87 out to new light.
87 new light out 12V
30 12v fuzed supply from batt positive.
85 switch neg goes into the cab, to the one side of a switch, other side of the switch goes to ground.
86 ground to chassis
Old Mar 4, 2013 | 06:13 PM
  #10353
stewie01's Avatar
stewie01
Off topic to help
Thanks.
I'll have to pickup another relay as I only got 1.
Old Mar 4, 2013 | 06:22 PM
  #10354
crazzywolfie's Avatar
crazzywolfie
if you got to go to the parts store you may want to buy yourself a stud type circuit breaker with the right amperage rating instead of a fuse. then you should never have to worry about blowing a fuse.
Old Mar 5, 2013 | 12:04 AM
  #10355
CSDavies26's Avatar
CSDavies26
Finished up puttin on new front hub bearings and u joints...both were still from factory. Surprisingly, the hubs came out without needing too much "encouragement"...odd thing tho, once i was done installing and fired it up, the abs and red "brake" lights were both on. Have no idea why since there arent any sensors on the front hubs, maybe just another weird thing the 2nd gen computers do. I just yanked the neg. terminal, turned the headlights on, and did the magic dance to the dodge gods and they went out. strange.
Old Mar 5, 2013 | 09:43 AM
  #10356
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Thanks.
I'm running two, 100w lights on one relay.
Old Mar 5, 2013 | 12:32 PM
  #10357
Jigabop's Avatar
Jigabop
why bother with 100w lights?
get 35w HID's....even brighter than 100w lights, and far less heat output and power draw.
they are ridiculously cheap these days...
nice and blinding too lol..
Old Mar 5, 2013 | 01:14 PM
  #10358
stewie01's Avatar
stewie01
Installed the BorgWarner Governor Solenoid and Pressure Sensor and a drain plug
Old Mar 5, 2013 | 05:18 PM
  #10359
Johnn123's Avatar
Johnn123
Tranny feel better then it did Stewie?
Old Mar 5, 2013 | 05:44 PM
  #10360
stewie01's Avatar
stewie01
Haven't had a chance to do a "proper" test drive, short drive was good.
