Old Mar 22, 2013 | 11:49 PM
  #10531
Johnn123's Avatar
Johnn123
Maybe I should just keep it? It sure doesnt seem to wanna sell!
Old Mar 23, 2013 | 12:07 AM
  #10532
crazzywolfie's Avatar
crazzywolfie
i think you should keep it. you will never get your money back out of it.
Originally Posted by SparkMasterB
Search Google. There are some 10%'s out there. The one I used expired a few weeks ago. Dodgeforum regularly has a 5% post in the Vendor Group And Special Buys section.
i have searched and not come up with anything. there was also even a post from rock auto Representative that say 5% is all they do since they already offer fairly reasonably priced parts.
Old Mar 23, 2013 | 07:29 AM
  #10533
renardk764's Avatar
renardk764
Drove to GDStock's and he hooked up the MT2500 scan tool to run a diagnostic baseline for me. Everything looked good except the governor solenoid pressure. Will be ordering a Borg Warner replacement shortly as well as replacement pressure sensor, and lock up solenoid. Pressure reading was at 78 instead of 120. Thanks GD! Enjoyed the conversion immensely !
Old Mar 23, 2013 | 08:12 AM
  #10534
SparkMasterB's Avatar
SparkMasterB
Hm. I guess 5% it is then. Maybe I had 2 5%'s that worked together? I know I had entered several codes seeing if any were worth more. The parts were ordered around a month ago and I had about $30 off an order that totaled around $300. Either way, I still saved a good 30-40% off local retail. Local stores (NAPA,Advanced,Carquest, even tried autozone) wanted well over $200 for the fuel pump, and double on the brake parts.
Old Mar 23, 2013 | 12:57 PM
  #10535
Johnn123's Avatar
Johnn123
Yea just what Im thinkin... I think ill just park it for now. Anything I should do to prep it for a long sit? Itll be a long time before I can put it back on the road.
Old Mar 23, 2013 | 01:09 PM
  #10536
stewie01's Avatar
stewie01
Some Stabilizer for the fuel maybe.....
Old Mar 23, 2013 | 01:19 PM
  #10537
Johnn123's Avatar
Johnn123
Stewie there wont be any left when I pull it :P
edit: I ordered a haynes manual so i can fix my front end while it sits. Need to a set of ball joints, and a passenger wheel bearing and ebrake.
Old Mar 23, 2013 | 01:58 PM
  #10538
merc225hp's Avatar
merc225hp
At a minimum engine oil change and fog the motor down, 50/50 antifreeze mix.
Do it right 90% of the fluids should be changed out, motor fogged, back off all the rockers, charge the batt and take it out of the truck and store it the right way, put it on jack stand via the frame until at least 50% of the load is off the suspension, put more jack-stands under the diff's, take the tires off it, use garbage bags to cover the diff ends, wash it, wax it, moth ball the interior, use air dryz in the cab, etc.
Old Mar 23, 2013 | 03:50 PM
  #10539
crazzywolfie
why will it be a long time before you put it back on the road?
i wouldn't use a normal fuel stabilizer. i would go for ethanol free 91 octane gas and some startron fuel treatment. it is suppose act as a fuel stabilizer plus should also help take care of some of the problem that running ethanol fuel cause.
Old Mar 23, 2013 | 05:51 PM
  #10540
gdstock's Avatar
gdstock
Great aternoon (especially getting away from the office early). Get a VB kit and bring her back and we'll slap that in it as well! Couldn't hurt!
Having to work on getting the garage sorted out a little better today since weather is so nice. May start wiring Ram for car trailer winch connection today.
